05-10-2013 02:45 PM - edited 03-16-2019 05:16 PM
I'm fighting with a T1 CAS implementation with BTC. So far I've set up only ISDN trunks and I've a lot of difficulties so help is higly appreciated.
T1 config is ok according to Telco requirements. Clock synchronized.
controller T1 0/0/0
framing SF
linecode ami
cablelength long 0db
ds0-group 0 timeslots 1-24 type e&m-wink-start
description LINK to BTC
voice-port 0/0/0:0
description BTC
bearer-cap 3100Hz
If I create a voice translation-rule for called numbers like below it rings and I have voice.
voice translation-rule 2
rule 1 /^$/ /7512199/
But if I want to match my internal devices I need to configure the rule as below, but I have a busy tone.
rule 1 /^.*\(2...$\)/ /751\1/
I don't know how to deal with incoming calls as the Telco seems not sending me any digits. I've atached the debug vpm signal.
Solved! Go to Solution.
05-11-2013 07:22 AM
As indicated above, wink timeout, indicates telco problem - no matter what they claim.
018738: May 11 16:10:39.411: htsp_process_event: [0/0/0:0(8), EM_WAIT_WINKUP, E_HTSP_EVENT_TIMER]em_wink_timeout
05-10-2013 03:36 PM
Adding (in bold)
ds0-group 0 timeslots 1-24 type e&m-wink-start dtmf dnis solved incoming call problem.
But the problem is on the outgoing call side.
Here is the debug vpm signal log.I've dialed 9 for outgoing, then the international prefix and the number.
007716: May 11 00:34:14: htsp_timer_stop3 htsp_setup_req
007717: May 11 00:34:14: Orig called num:901141227092477
007718: May 11 00:34:14: htsp_process_event: [0/0/0:0(9), EM_ONHOOK, E_HTSP_SETUP_REQ]em_onhook_setup
007719: May 11 00:34:14: em_offhook (0)vnm_dsp_set_sig_state:[recEive and transMit0/0/0:0(9)] set signal state = 0x8
007720: May 11 00:34:14: htsp_process_event: [0/0/0:0(9), EM_BRANCH, EM_EVENT_WINK]
007721: May 11 00:34:14: em_start_timer: 550 ms
007722: May 11 00:34:14: htsp_timer - 550 msec
007723: May 11 00:34:14: htsp_process_event: [0/0/0:0(9), EM_WAIT_WINKUP, E_HTSP_EVENT_TIMER]em_wink_timeout
007724: May 11 00:34:14: em_stop_timers
007725: May 11 00:34:14: htsp_timer_stop2 em_onhook (0)vnm_dsp_set_sig_state:[recEive and transMit0/0/0:0(9)] set signal state = 0x0
007726: May 11 00:34:14: em_start_timer: 400 ms
007727: May 11 00:34:14: htsp_timer - 400 msec
007728: May 11 00:34:14: htsp_process_event: [0/0/0:0(9), EM_GUARD_ALL, E_HTSP_RELEASE_REQ]
007729: May 11 00:34:15: htsp_process_event: [0/0/0:0(9), EM_GUARD_ALL_RLS_REQ, E_HTSP_EVENT_TIMER]em_guard_all_timer
007730: May 11 00:34:15: em_stop_timers
007731: May 11 00:34:15: htsp_timer_stop
007732: May 11 00:34:15: em_stop_timers
007733: May 11 00:34:15: htsp_timer_stop2
007734: May 11 00:34:15: em_start_timer: 3000 ms
007735: May 11 00:34:15: htsp_timer - 3000 msec
007736: May 11 00:34:15: htsp_process_event: [0/0/0:0(9), EM_PARK, E_DSP_SIG_0000]em_park_onhook
007737: May 11 00:34:15: htsp_timer_stop
007738: May 11 00:34:15: htsp_timer_stop2 htsp_report_onhook_sig
JC,
05-11-2013 03:58 AM
Seems like there is a timing problem, but can't be sure, because there is no millisecods in debug output.
Anyway, if you see no wink coming, that means the CO is not set for wink start, no matter what they claim.
05-11-2013 06:38 AM
I can see incoming wink. And the Telco has confirmed it is a wink / wink config.
Incoming is ok now.
For outgoing calls I've set up the voice port with
voice-port 0/0/0:0
translation-profile incoming TRANSLATION_IN
translation-profile outgoing TRANSLATION_OUT
timing dialout-delay 1000
And also corrected the dial-peer and it works...for 1 call.
But when there are several outgoing calls within I would say 5 seconds there is a busy tone with DISC CAUSE CODE 44 no requested circuit
example of busy with disc cause 44
014827: May 11 15:37:27.586: htsp_timer_stop3 htsp_setup_req
014828: May 11 15:37:27.586: Orig called num:01141227093182
014829: May 11 15:37:27.586: htsp_process_event: [0/0/0:0(2), EM_ONHOOK, E_HTSP_SETUP_REQ]em_onhook_setup
014830: May 11 15:37:27.586: em_offhook (0)vnm_dsp_set_sig_state:[recEive and transMit0/0/0:0(2)] set signal state = 0x8
014831: May 11 15:37:27.586: htsp_process_event: [0/0/0:0(2), EM_BRANCH, EM_EVENT_WINK]
014832: May 11 15:37:27.586: em_start_timer: 550 ms
014833: May 11 15:37:27.586: htsp_timer - 550 msec
014834: May 11 15:37:28.138: htsp_process_event: [0/0/0:0(2), EM_WAIT_WINKUP, E_HTSP_EVENT_TIMER]em_wink_timeout
014835: May 11 15:37:28.138: em_stop_timers
014836: May 11 15:37:28.138: htsp_timer_stop2 em_onhook (0)vnm_dsp_set_sig_state:[recEive and transMit0/0/0:0(2)] set signal state = 0x0
014837: May 11 15:37:28.138: em_start_timer: 400 ms
014838: May 11 15:37:28.138: htsp_timer - 400 msec
014839: May 11 15:37:28.138: htsp_process_event: [0/0/0:0(2), EM_GUARD_ALL, E_HTSP_RELEASE_REQ]
014840: May 11 15:37:28.538: htsp_process_event: [0/0/0:0(2), EM_GUARD_ALL_RLS_REQ, E_HTSP_EVENT_TIMER]em_guard_all_timer
014841: May 11 15:37:28.538: em_stop_timers
014842: May 11 15:37:28.538: htsp_timer_stop
014843: May 11 15:37:28.538: em_stop_timers
014844: May 11 15:37:28.538: htsp_timer_stop2
014845: May 11 15:37:28.538: em_start_timer: 3000 ms
014846: May 11 15:37:28.538: htsp_timer - 3000 msec
014847: May 11 15:37:28.538: htsp_process_event: [0/0/0:0(2), EM_PARK, E_DSP_SIG_0000]em_park_onhook
014848: May 11 15:37:28.538: htsp_timer_stop
014849: May 11 15:37:28.538: htsp_timer_stop2 htsp_report_onhook_sig
014850: May 11 15:37:31.982: htsp_timer_stop3 htsp_setup_req
014851: May 11 15:37:31.982: Orig called num:3022115
014852: May 11 15:37:31.982: htsp_process_event: [0/0/0:0(9), EM_ONHOOK, E_HTSP_SETUP_REQ]em_onhook_setup
014853: May 11 15:37:31.982: em_offhook (0)vnm_dsp_set_sig_state:[recEive and transMit0/0/0:0(9)] set signal state = 0x8
014854: May 11 15:37:31.982: htsp_process_event: [0/0/0:0(9), EM_BRANCH, EM_EVENT_WINK]
014855: May 11 15:37:31.982: em_start_timer: 550 ms
014856: May 11 15:37:31.982: htsp_timer - 550 msec
014857: May 11 15:37:32.534: htsp_process_event: [0/0/0:0(9), EM_WAIT_WINKUP, E_HTSP_EVENT_TIMER]em_wink_timeout
014858: May 11 15:37:32.534: em_stop_timers
014859: May 11 15:37:32.534: htsp_timer_stop2 em_onhook (0)vnm_dsp_set_sig_state:[recEive and transMit0/0/0:0(9)] set signal state = 0x0
014860: May 11 15:37:32.534: em_start_timer: 400 ms
014861: May 11 15:37:32.534: htsp_timer - 400 msec
014862: May 11 15:37:32.534: htsp_process_event: [0/0/0:0(9), EM_GUARD_ALL, E_HTSP_RELEASE_REQ]
014863: May 11 15:37:32.934: htsp_process_event: [0/0/0:0(9), EM_GUARD_ALL_RLS_REQ, E_HTSP_EVENT_TIMER]em_guard_all_timer
014864: May 11 15:37:32.934: em_stop_timers
014865: May 11 15:37:32.934: htsp_timer_stop
014866: May 11 15:37:32.934: em_stop_timers
014867: May 11 15:37:32.934: htsp_timer_stop2
014868: May 11 15:37:32.934: em_start_timer: 3000 ms
014869: May 11 15:37:32.934: htsp_timer - 3000 msec
014870: May 11 15:37:32.934: htsp_process_event: [0/0/0:0(9), EM_PARK, E_DSP_SIG_0000]em_park_onhook
014871: May 11 15:37:32.934: htsp_timer_stop
014872: May 11 15:37:32.934: htsp_timer_stop2 htsp_report_onhook_sig
014873: May 11 15:37:36.658: htsp_timer_stop3 htsp_setup_req
014874: May 11 15:37:36.658: Orig called num:5655569
014875: May 11 15:37:36.658: htsp_process_event: [0/0/0:0(3), EM_ONHOOK, E_HTSP_SETUP_REQ]em_onhook_setup
014876: May 11 15:37:36.658: em_offhook (0)vnm_dsp_set_sig_state:[recEive and transMit0/0/0:0(3)] set signal state = 0x8
014877: May 11 15:37:36.658: htsp_process_event: [0/0/0:0(3), EM_BRANCH, EM_EVENT_WINK]
014878: May 11 15:37:36.658: em_start_timer: 550 ms
014879: May 11 15:37:36.658: htsp_timer - 550 msec
014880: May 11 15:37:37.210: htsp_process_event: [0/0/0:0(3), EM_WAIT_WINKUP, E_HTSP_EVENT_TIMER]em_wink_timeout
What is the reason ?
thanks,
05-11-2013 07:12 AM
To add more precision here is the call output that fails
018731: May 11 16:10:38.859: htsp_timer_stop3 htsp_setup_req
018732: May 11 16:10:38.859: Orig called num:3022131
018733: May 11 16:10:38.859: htsp_process_event: [0/0/0:0(8), EM_ONHOOK, E_HTSP_SETUP_REQ]em_onhook_setup
018734: May 11 16:10:38.859: em_offhook (0)vnm_dsp_set_sig_state:[recEive and transMit0/0/0:0(8)] set signal state = 0x8
018735: May 11 16:10:38.859: htsp_process_event: [0/0/0:0(8), EM_BRANCH, EM_EVENT_WINK]
018736: May 11 16:10:38.859: em_start_timer: 550 ms
018737: May 11 16:10:38.859: htsp_timer - 550 msec
018739: May 11 16:10:39.411: em_stop_timers
018740: May 11 16:10:39.411: htsp_timer_stop2 em_onhook (0)vnm_dsp_set_sig_state:[recEive and transMit0/0/0:0(8)] set signal state = 0x0
018741: May 11 16:10:39.411: em_start_timer: 400 ms
018742: May 11 16:10:39.411: htsp_timer - 400 msec
018743: May 11 16:10:39.411: htsp_process_event: [0/0/0:0(8), EM_GUARD_ALL, E_HTSP_RELEASE_REQ]
018744: May 11 16:10:39.811: htsp_process_event: [0/0/0:0(8), EM_GUARD_ALL_RLS_REQ, E_HTSP_EVENT_TIMER]em_guard_all_timer
018745: May 11 16:10:39.811: em_stop_timers
018746: May 11 16:10:39.811: htsp_timer_stop
018747: May 11 16:10:39.811: em_stop_timers
018748: May 11 16:10:39.811: htsp_timer_stop2
018749: May 11 16:10:39.811: em_start_timer: 3000 ms
018750: May 11 16:10:39.811: htsp_timer - 3000 msec
018751: May 11 16:10:39.811: htsp_process_event: [0/0/0:0(8), EM_PARK, E_DSP_SIG_0000]em_park_onhook
018752: May 11 16:10:39.811: htsp_timer_stop
018753: May 11 16:10:39.811: htsp_timer_stop2 htsp_report_onhook_sightsp_call_service_msghtsp_call_service_msg not EFXS (1)
018754: May 11 16:10:41.023: htsp_process_event: [0/0/0:0(21), EM_CONNECT, E_HTSP_VOICE_CUT_THROUGH]htsp_call_service_msghtsp_call_service_msg not EFXS (1)htsp_call_service_msghtsp_call_service_msg not EFXS (1)
05-11-2013 07:22 AM
05-11-2013 07:27 AM
Thanks.
But sometimes it works for outgoing calls, sometimes not.
So it may be a Timer problem ? Can I adjust it on my side or on their side ?
05-11-2013 08:40 AM
Even with increased "timing wait-wink 1100" under voice-port it happens sometimes again.
021175: May 11 17:35:39.382: htsp_timer_stop3 htsp_setup_req
021176: May 11 17:35:39.382: Orig called num:3022131
021177: May 11 17:35:39.382: htsp_process_event: [0/0/0:0(12), EM_ONHOOK, E_HTSP_SETUP_REQ]em_onhook_setup
021178: May 11 17:35:39.382: em_offhook (0)vnm_dsp_set_sig_state:[recEive and transMit0/0/0:0(12)] set signal state = 0x8
021179: May 11 17:35:39.382: htsp_process_event: [0/0/0:0(12), EM_BRANCH, EM_EVENT_WINK]
021180: May 11 17:35:39.382: em_start_timer: 1100 ms
021181: May 11 17:35:39.382: htsp_timer - 1100 msec
021182: May 11 17:35:40.482: htsp_process_event: [0/0/0:0(12), EM_WAIT_WINKUP, E_HTSP_EVENT_TIMER]em_wink_timeout
021183: May 11 17:35:40.482: em_stop_timers
I'll try increasing values...And let you know.
Edit : With wait-wink set at its maximum 6500 ms same result. So definitely like Paolo Bevilacqua said : telco problem...
05-11-2013 09:20 AM
So for channels 1 to 12 included , outgoing calls always fail with Wink timeout.
With channels 13 to 24 it always work.
What are the possibilities if the Telco doe snothing to help me ?
Can I create 2 groups of channels, 1 for incoming and 1 for outgoing calls ?
05-11-2013 09:32 AM
Yes, you can create multiple ds0- groups.
If you tell telco that lower channels are behaving differently than the high ones, eventually they will, slowly and reluctantly, look and fix the issue.
Thank you for the nice rating and good luck!
05-11-2013 03:07 PM
Finally problem solved by asking Telco to change the lower channels behaviour.
As Telco said "Trunks are currently configured as 12 incoming & 12 outgoing"
So now they are configured as 24 incoming and outgoing.
The rating is normal because you've found the root cause that has helped me to debug this strange behaviour.
Thanks for help.
