03-20-2018 07:04 AM - edited 03-17-2019 12:27 PM
Hi Cisco Expertise,
Blessed day!
May we ask for your help to convert my dat file to wav? Or is there any app can you recommend to me please?
Thank you.
Best Regards,
Ralph
03-20-2018 03:10 PM
there are plenty apps for this for free online that can do this for you. all comes down to personal preference
03-20-2018 06:17 PM
There is a tech note published on this. Refer to this link.
You can also try Switch made by NCH Software.
03-22-2018 09:55 PM
Hi Rejohn,
Thanks for your reply. I will check on this.
