Help me to convert pcm.dat to wav file
Hi Cisco Expertise,
Blessed day!
May we ask for your help to convert my dat file to wav? Or is there any app can you recommend to me please?
Thank you.
Best Regards,
Ralph
Dennis Mink
there are plenty apps for this for free online that can do this for you. all comes down to personal preference
Please remember to rate useful posts, by clicking on the stars below.
Rejohn Cuares
Level 4
Level 4
There is a tech note published on this. Refer to this link.
https://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-system/115749-analyze-pcm-data.html
You can also try Switch made by NCH Software.
Please rate replies and mark question as "answered" if applicable.
Hi Rejohn,
Thanks for your reply. I will check on this.
