HELP. Voice mail is not working
Dfulgencio
I'm having problems with a voicemail.
Scenario:
CME configure with a Unity Express for voice mail. When i call from the PSTN the Auto-Attendat picks up the call,
the call is transfer to an extension.  I let the extension ring until forward the call to the voicemail.
Once i hear the message "leave your message for xxxx", i leave the message but the mailbox doesn't receive any message. The phone doesn't turn on
the light indicating a new message has arrived.  I have configure MWI  on the CME. I also have configure the voice mail in the unity:
CME:
ephone-dn  61
number A61.... no-reg primary
description FOR MWI-ON
mwi on
ephone-dn  62
number A62.... no-reg primary
description FOR MWI-OFF
mwi off
dial-peer voice 5000 voip
description *** FOR VOICE MAIL ****
destination-pattern 5000
session protocol sipv2
session target ipv4:10.234.144.254
dtmf-relay sip-notify rtp-nte
codec g711ulaw
no vad
UNITY VOICEMAIL CONFIG:
voicemail mailbox owner "Rigsanchez" size 5400
description "Rigoberto Sanchez mailbox"
end mailbox
Other thing i noticed is that when i'm leaving the message and press #, for more option,  the system tells me that the message is too short.
Can somebody help me?
Thansk for your response
17 Replies 17
Can u try adding this while trying g729r8 (default) codec ?
sip-ua
g729-annexb override  <--- add this (hidden so pl. just type)
Hi Dilip,
I tried the last command you told me and now is working fine.
Thanks a lot for your help.
Hi there,
Great! I am glad that it worked out....
That command causes IOS to interop with systems
not compliant with rfc 3555.
Pl. mark this thread as answered and
rate as appropriate..
Thx,
DK
