High packet loss while accessing Cisco Unity Connection 8.0
Hi All Networkers,
This is Niran.  I've installed Cisco Unity Connection 8.0 on VMwareworkstation (72 gb & 2gb ram, Bridged). I'm getting high packet loss while pinging the CUC and takes long time to load the web session.
Here is the ping response :
Reply from 192.168.1.11: bytes=32 time<1ms TTL=64
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 192.168.1.11: bytes=32 time=1ms TTL=64
Request timed out.
Request timed out.
Ping statistics for 192.168.1.11:
    Packets: Sent = 899, Received = 659, Lost = 240
Approximate round trip times in milli-seconds:
    Minimum = 0ms, Maximum = 1999ms, Average = 7ms
Please let me know what may be the problem. Thanks in advance.
Jaime Valencia
Losing pings is expected, it's a security mechanism.
Slow web access usually points to the fact you're not dedicating the whole memory as you should to the VM.
How much memory does the server/PC/etc has where you installed it?
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Also, check your duplex settings on the NIC to ensue you are running Full Duplex.
HTH,
Chris
Chris,
I checked my duplex settings, it is Full Duplex
My PC configuration is I7 @ 2.20 ghz, 8gb ram and I allocated 2 GB RAM and 72 GB HD for my VMware.
