host not found error CP 7942g
abd88elhak
i have configured extension mobility on CUCM 10.5 but i faced the error message (host not found )when i press service button on some phones 7942g but others work fine
all ip phones are the same  (7942) and also have similar configuration
regards
Manish Gogna
A couple of things that you can try are :
Try deleting the ITL file on affected phones.
Unsubscribe and resubscribe the extension mobility service on IP phones.
If the issue persists, get a packet capture from the ip phone while reproducing the issue.
Manish
Brandon Pierce
Level 4
Level 4
Make sure DNS reliance is disabled by putting in the IPs for all the service URLs as well.  This can cause the issue.
