How can i monitor IP phone through Callmanager
Cristian Mena
Hello, i'm new at this and really could use some help. I need to monitor Cisco IP phones through SNMP. I know Cisco IP phones does not support SNMP, but i need to know how i can pull information through SNMP using the call manager. Hope you can help me.
You can use Real Time Monitoring Tool [RTMT] but it wont use SNMP Polling. Check the below link
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/service/8_5_1/rtmt/RTMT/rtconfcm.html
Abhay
Abhay Singh Reyal
The Only Way To Do Great Work Is To Love What You Do. If You Haven’t Found It Yet, Keep Looking. Don’t Settle
Jaime Valencia
It would help if you explain exactly what information you're trying to get from the endpoint.
java
if this helps, please rate
I need to monitor status of the phone, if it registred, alerts like temperature alerts  and that kind of stuff.
