Busy Tone when calling
Julio_groeli
Hello, I have a CME 7.1 with fourteen 7911 ip phones and four 4942 phones.
When I place a call from any phone it gets a busy tone at random times, and I need to call several times to the same number until the call goes through.
Does anyone has experienced that?
22 Replies 22
Jaime Valencia
Are they all registered to the same CME??
java
if this helps, please rate
Yes, they are all registered to the same CME.
Can you please post your configuration.
HTH Regards, Yosh
Sure, I already posted my configuration in this thread.
Thank you for your reply.
Try using the below command and post the capture for when its working and when you get the busy ringtone.
debug voip ccapi inout
This is the result of debug voip ccapi inout when the getting the busy tone after dialing to an external number:
ul 17 15:19:52.023: //253/9F11465D82DE/CCAPI/cc_api_call_digit_end:
   Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
   Source Call Id=253, Digit=4, Duration=100,
   Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Jul 17 15:19:52.023: //253/9F11465D82DE/CCAPI/cc_api_call_digit_end:
   Call Entry(Handoff Depth=0)
Jul 17 15:19:52.027: //253/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
   (callID=0xFD, digit_event=0x0, enable=FALSE, consume=FALSE)
Jul 17 15:19:52.027: //253/9F11465D82DE/CCAPI/ccCallReportDigits:
   Enabled=TRUE, Call Id=253
Jul 17 15:19:52.027: //253/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x67935488, callID=0xFD, disp=0, digit_event=0x0, enable=FALSE, consu
me=FALSE)
Jul 17 15:19:52.027: //253/9F11465D82DE/CCAPI/cc_api_call_report_digits_done:
   Enabled=TRUE, Disposition=0x0, Interface=0x67935488, Call Id=253
   Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=10000(ms))
Jul 17 15:19:52.027: //253/9F11465D82DE/CCAPI/ccCallProceeding:
   Progress Indication=NULL(0)
Jul 17 15:19:52.031: //253/9F11465D82DE/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=31, Params=0x658B7214, Progress Indication=ORIGINATING SID
E IS NON ISDN(3)
Jul 17 15:19:52.031: //253/9F11465D82DE/CCAPI/ccCheckClipClir:
   In: Calling Number=2006(TON=Unknown, NPI=Unknown, Screening=Not Screened, Pre
sentation=Allowed)
   Out: Calling Number=2006(TON=Unknown, NPI=Unknown, Screening=Not Screened, Pr
esentation=Allowed)
Jul 17 15:19:52.035: //253/9F11465D82DE/CCAPI/ccCallSetupRequest:
   Destination Pattern=904[45].........., Called Number=90448341064684, Digit St
rip=TRUE
   Calling Number=2006(TON=Unknown, NPI=Unknown, Screening=Not Screened, Present
ation=Allowed),
   Called Number=90448341064684(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=Julio
   Account Number=, Final Destination Flag=FALSE,
   Guid=9F11465D-0CFC-11E4-82DE-D9073BD41B29, Outgoing Dial-peer=31
Jul 17 15:19:52.035: //253/9F11465D82DE/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=2006
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=90448341064684
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Jul 17 15:19:52.035: //253/9F11465D82DE/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x6623758C, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=2006,(Calling Name=Julio)(TON=Unknown, NPI=Unknown
, Screening=Not Screened, Presentation=Allowed),
   Called Number=90448341064684(TON=Unknown, NPI=Unknown), Calling Translated=FA
LSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-pe
er=31, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Appl
ication Call Id=)
Jul 17 15:19:52.035: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jul 17 15:19:52.035: :cc_get_feature_vsa malloc success
Jul 17 15:19:52.035:  cc_get_feature_vsa count is 2
Jul 17 15:19:52.035: :FEATURE_VSA attributes are: feature_name:0,feature_time:17
41707352,feature_id:338
Jul 17 15:19:52.035: //254/9F11465D82DE/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Jul 17 15:19:52.035: //254/9F11465D82DE/CCAPI/ccCallSetContext:
   Context=0x658B71C4
Jul 17 15:19:52.035: //253/9F11465D82DE/CCAPI/ccSaveDialpeerTag:
Jul 17 15:20:00.039: //254/9F11465D82DE/CCAPI/cc_api_call_disconnected:
   Cause Value=41, Interface=0x6623758C, Call Id=254
   Call Entry(Responsed=TRUE, Cause Value=41, Retry Count=0)
Jul 17 15:20:00.039: //253/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
Jul 17 15:20:00.039: //254/9F11465D82DE/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=254
Jul 17 15:20:00.039: //254/9F11465D82DE/CCAPI/ccCallDisconnect:
   Cause Value=41, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect C
ause=41)
   Cause Value=41, Call Entry(Responsed=TRUE, Cause Value=41)
Jul 17 15:20:00.039: //254/9F11465D82DE/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Jul 17 15:20:00.043: //254/9F11465D82DE/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x6623758C, Tag=0x0, Call Id=254,
   Call Entry(Disconnect Cause=41, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Jul 17 15:20:00.043: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 17 15:20:00.043: :cc_free_feature_vsa freeing 67D05850
Jul 17 15:20:00.043:  vsacount in free is 1
Jul 17 15:20:00.047: //253/9F11465D82DE/CCAPI/ccCallDisconnect:
ause=0)
Jul 17 15:20:00.047: //253/9F11465D82DE/CCAPI/cc_api_get_transfer_info:
This is the result of debug voip ccaip inout when the call is working after dialing to an external number:
Jul 17 15:55:05.351: //259/8B80275482F0/CCAPI/ccCallReportDigits:
   Enabled=TRUE, Call Id=259
Jul 17 15:55:05.351: //259/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x67935488, callID=0x103, disp=0, digit_event=0x0, enable=FALSE, cons
ume=FALSE)
Jul 17 15:55:05.351: //259/8B80275482F0/CCAPI/cc_api_call_report_digits_done:
   Enabled=TRUE, Disposition=0x0, Interface=0x67935488, Call Id=259
Jul 17 15:55:05.351: //259/8B80275482F0/CCAPI/ccCallProceeding:
Jul 17 15:55:05.355: //259/8B80275482F0/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=31, Params=0x658AECDC, Progress Indication=ORIGINATING SID
E IS NON ISDN(3)
Jul 17 15:55:05.355: //259/8B80275482F0/CCAPI/ccCheckClipClir:
sentation=Allowed)
esentation=Allowed)
rip=TRUE
ation=Allowed),
   Guid=8B802754-0D01-11E4-82F0-D9073BD41B29, Outgoing Dial-peer=31
Jul 17 15:55:05.355: //259/8B80275482F0/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=2006
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=90448341064684
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Jul 17 15:55:05.359: //259/8B80275482F0/CCAPI/ccIFCallSetupRequestPrivate:
LSE,
ication Call Id=)
Jul 17 15:55:05.359: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jul 17 15:55:05.359: :cc_get_feature_vsa malloc success
Jul 17 15:55:05.359:  cc_get_feature_vsa count is 2
Jul 17 15:55:05.359: :FEATURE_VSA attributes are: feature_name:0,feature_time:17
23400800,feature_id:344
Jul 17 15:55:05.359: //260/8B80275482F0/CCAPI/ccIFCallSetupRequestPrivate:
Jul 17 15:55:05.359: //260/8B80275482F0/CCAPI/ccCallSetContext:
   Context=0x658AEC8C
Jul 17 15:55:05.359: //259/8B80275482F0/CCAPI/ccSaveDialpeerTag:
Jul 17 15:55:05.415: %ENVMON-4-FAN_LOW_RPM: Fan 2 service recommended
Jul 17 15:55:05.763: //260/8B80275482F0/CCAPI/cc_api_call_proceeding:
   Interface=0x6623758C, Progress Indication=NULL(0)
Jul 17 15:55:18.211: //260/8B80275482F0/CCAPI/cc_api_call_alert:
   Interface=0x6623758C, Progress Indication=INBAND(8), Signal Indication=SIGNAL
 RINGBACK(1)
   Call Entry(Retry Count=0, Responsed=TRUE)
Jul 17 15:55:18.211: //259/8B80275482F0/CCAPI/ccCallAlert:
   Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1)
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Jul 17 15:55:18.211: //259/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x65865310, callID1=0x103, callID2=0x104, tag=0x0)
   (confID=0x65865310, callID1=0x103, gcid=8B802754-D0111E4-82F0D907-3BD41B29, t
ag=0x0)
Jul 17 15:55:18.211: //260/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x65865310, callID2=0x104, gcid=8B802754-D0111E4-82F0D907-3BD41B29, t
ag=0x0)
Jul 17 15:55:18.211: //259/8B80275482F0/CCAPI/ccConferenceCreate:
   Conference Id=0x65865310, Call Id1=259, Call Id2=260, Tag=0x0
Jul 17 15:55:18.211: //259/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x32, Source Interface=0x67935488, Source Call Id=259,
   Destination Call Id=260, Disposition=0x0, Tag=0xFFFFFFFF
Jul 17 15:55:18.211: //260/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x32, Source Interface=0x6623758C, Source Call Id=260,
   Destination Call Id=259, Disposition=0x0, Tag=0xFFFFFFFF
Jul 17 15:55:18.215: //259/8B80275482F0/CCAPI/cc_generic_bridge_done:
Jul 17 15:55:18.215: //259/8B80275482F0/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x32, Destination Call Id=260)
Jul 17 15:55:18.215: //260/8B80275482F0/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x32, Destination Call Id=259)
Jul 17 15:55:18.215: //259/8B80275482F0/CCAPI/cc_api_caps_ind:
   Destination Interface=0x6623758C, Destination Call Id=260, Source Call Id=259
   Caps(Codec=0x1, Fax Rate=0x2, Vad=0x1,
   Modem=0x2, Codec Bytes=160, Signal Type=2)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
Jul 17 15:55:18.215: //260/8B80275482F0/CCAPI/cc_api_caps_ind:
   Destination Interface=0x67935488, Destination Call Id=259, Source Call Id=260
   Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
Jul 17 15:55:18.215: //260/8B80275482F0/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=9306)
Jul 17 15:55:18.215: //259/8B80275482F0/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_NONE(0x1), Vad=OFF(0x1),
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=5385)
Jul 17 15:55:18.215: //259/8B80275482F0/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x32, Call Id1=259, Call Id2=260
Jul 17 15:55:18.219: //259/8B80275482F0/CCAPI/cc_api_voice_mode_event:
   Call Id=259
   Call Entry(Context=0x658C0A04)
Jul 17 15:55:18.219: //260/8B80275482F0/CCAPI/cc_api_voice_mode_event:
   Call Id=260
   Call Entry(Context=0x658AEC8C)
Jul 17 15:55:18.227: //259/8B80275482F0/CCAPI/ccCallFeature:
   Feature Type=25, Call Id=259
Jul 17 15:55:35.427: %ENVMON-4-FAN_LOW_RPM: Fan 2 service recommended
Jul 17 15:55:36.599: //259/8B80275482F0/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x67935488, Call Id=259
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Jul 17 15:55:36.599: //259/8B80275482F0/CCAPI/ccConferenceDestroy:
   Conference Id=0x32, Tag=0x0
Jul 17 15:55:36.603: //259/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=260, Disposition=0x0, Tag=0x0
Jul 17 15:55:36.603: //260/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=259, Disposition=0x0, Tag=0x0
Jul 17 15:55:36.603: //259/8B80275482F0/CCAPI/cc_generic_bridge_done:
Jul 17 15:55:36.603: //260/8B80275482F0/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect C
ause=0)
Jul 17 15:55:36.607: //260/8B80275482F0/CCAPI/ccCallDisconnect:
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Jul 17 15:55:36.607: //260/8B80275482F0/CCAPI/cc_api_get_transfer_info:
Jul 17 15:55:36.607: //259/8B80275482F0/CCAPI/ccCallDisconnect:
ause=16)
Jul 17 15:55:36.607: //259/8B80275482F0/CCAPI/cc_api_get_transfer_info:
Jul 17 15:55:36.619: //259/8B80275482F0/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x67935488, Tag=0x0, Call Id=259,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Jul 17 15:55:36.619: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 17 15:55:36.619: :cc_free_feature_vsa freeing 66B90338
Jul 17 15:55:36.619:  vsacount in free is 1
Jul 17 15:55:36.767: //260/8B80275482F0/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x6623758C, Tag=0x0, Call Id=260,
Jul 17 15:55:36.767: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 17 15:55:36.767: :cc_free_feature_vsa freeing 66B90258
Jul 17 15:55:36.767:  vsacount in free is 0
I see in the debug that the called number you're sending to the PSTN is prefixed with 9 (which is incorrect).
In your config there are a lot of "direct-inward-dial".
You should use it only when receiving calls from the voice-port 0/1/0:0.
Remove the direct-inward-dial" from the outgoing dial-peers and create a new dial-peer voice containing :
Dial-peer voice 60 pots
incoming called-number
direct-inward-dial
voice-port 0/1/0:0
End
you should remove the direct-inward-dial from the outgoing dial-peers (which are dial-peers 10, 21, 31, 40 and 52). You putting the command in the wrong dial-peers
Thank you for your reply. I did the changes you mentioned but I´m still getting the same error found on debug.
Can you post your show run and the output of debug voip ccapi inout after the previous modifications ?
Sure,
This is the result of show running-config
CME#show run
Building configuration...
Current configuration : 14484 bytes
! Last configuration change at 04:01:20 CST Mon Jul 21 2014 by fersvam
! NVRAM config last updated at 09:55:07 CST Mon Jul 21 2014
version 12.4
hostname CME
boot-start-marker
boot-end-marker
card type e1 0 1
logging message-counter syslog
enable secret 5 $1$W.WI$18PreLIBeu/lO41AIMZB81
no aaa new-model
clock timezone CST -6
network-clock-participate wic 1
network-clock-select 1 E1 0/1/0
dot11 syslog
ip source-route
ip cef
no ip domain lookup
ip domain name svam.com
no ipv6 cef
voice service voip
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 no supplementary-service h450.3
 fax protocol cisco
voice class codec 1
 codec preference 1 g711ulaw
 codec preference 3 g729r8
voice-card 0
 dsp services dspfarm
crypto pki trustpoint TP-self-signed-391591381
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-391591381
 revocation-check none
 rsakeypair TP-self-signed-391591381
crypto pki certificate chain TP-self-signed-391591381
 certificate self-signed 01
  30820242 308201AB A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33393135 39313338 31301E17 0D313131 30323432 30313731
  315A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
  532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3339 31353931
  33383130 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
  E83DA404 49A1491B 94CF3A63 B319CA8D 0408F3E9 AE19733E A48C85C4 2C7EA5D2
  FDEC6A4F 5DA284A5 6F5AC6D0 4BC695A0 8387C50D B9314C8F B25D2732 94DA1333
  DB699483 F11BA2A5 BD5833E2 ACF2D349 2953A748 0F546DCA B8FFDDEB 5AED7CD7
  D1421873 72D7433B 33D4EB8D 49FEF4B1 E5760AAC A6DCD113 2C4CCAED 98F31323
  02030100 01A36C30 6A300F06 03551D13 0101FF04 05300301 01FF3017 0603551D
  11041030 0E820C43 4D452E73 76616D2E 636F6D30 1F060355 1D230418 30168014
  313E07BE 74B07039 47E2E585 6CCCEA0C 69AF7D72 301D0603 551D0E04 16041431
  3E07BE74 B0703947 E2E5856C CCEA0C69 AF7D7230 0D06092A 864886F7 0D010104
  05000381 81009236 3F2BDF77 CCFF4EB9 D9FAC44A 184B0497 D5165D0C D5C5679B
  CF14D47D 8B18FE7E DE4B85B8 FFC0244E 8A511200 F4D69452 ED0B0FB9 9B25E503
  EFDE1E88 8647E398 1675B2EE 711CD4C4 F88FEAAE 4B05AC8E F1099AF2 83657A78
  6698B812 0C68A8B9 6DD4F46C F2D575CB 3CA777CA 28576712 1B3F4F33 FFE244A5
  1A34B302 B7CE
        quit
username fersvam privilege 15 password 0 20svam10
archive
 log config
  hidekeys
controller E1 0/1/0
 framing NO-CRC4
 line-termination 75-ohm
 ds0-group 0 timeslots 1-10 type r2-digital r2-compelled ani
 cas-custom 0
  country telmex
  category 2
  answer-signal group-b 1
  groupa-callerid-end
ip ftp username jguerrero
ip ftp password Y870818yy
class-map match-all cti-qbe
 match access-group 101
class-map match-any AutoQoS-VoIP-RTP-Trust
 match ip dscp ef
class-map match-any AutoQoS-VoIP-Control-Trust
 match ip dscp cs3
 match ip dscp af31
policy-map cti-qbe
 class cti-qbe
  set dscp af31
    bandwidth 20
policy-map AutoQoS-Policy-Trust
 class AutoQoS-VoIP-RTP-Trust
    priority percent 70
 class AutoQoS-VoIP-Control-Trust
    bandwidth percent 5
 class class-default
    fair-queue
interface FastEthernet0/0
 no ip address
 duplex auto
 speed auto
 auto qos voip trust
 service-policy output AutoQoS-Policy-Trust
interface FastEthernet0/0.1
 encapsulation dot1Q 1 native
 ip address 192.168.6.254 255.255.254.0
interface FastEthernet0/0.50
 description vlan voice
 encapsulation dot1Q 50
 ip address 192.168.8.254 255.255.255.0
interface Service-Engine0/0
 ip unnumbered FastEthernet0/0.1
 service-module ip address 192.168.6.253 255.255.254.0
 service-module ip default-gateway 192.168.6.254
interface FastEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.6.252
ip route 192.168.6.253 255.255.255.255 Service-Engine0/0
ip http server
ip http authentication local
ip http secure-server
access-list 101 permit tcp host 192.168.6.253 any eq 2748
tftp-server flash:P00305000301.sbn
tftp-server flash:P00403020214.bin
tftp-server flash:term11.default.loads
tftp-server flash:term06.default.loads
tftp-server flash:SCCP11.9-0-2SR1S.loads
tftp-server flash:jar11sccp.9-0-2ES2.sbn
tftp-server flash:dsp11.9-0-2ES2.sbn
tftp-server flash:cvm11sccp.9-0-2ES2.sbn
tftp-server flash:cnu11.9-0-2ES2.sbn
tftp-server flash:apps11.9-0-2ES2.sbn
control-plane
rmon event 33333 log trap AutoQoS description "AutoQoS SNMP traps for Voice Drops" owner AutoQoS
rmon alarm 33333 cbQosCMDropBitRate.34.5364641 30 absolute rising-threshold 1 33333 falling-threshold 0 owner AutoQoS
disable-eadi
voice-port 0/0/0
 supervisory disconnect dualtone mid-call
 input gain 2
 echo-cancel coverage 24
 no comfort-noise
 cptone MX
 timeouts interdigit 5
 timeouts call-disconnect 5
 timeouts wait-release 5
 timing hookflash-out 50
 connection plar 2002
 station-id name SVAM
 station-id number 8343126439
 caller-id enable
voice-port 0/0/1
 input gain 2
 no comfort-noise
 cptone MX
 connection plar 2004
 station-id name SVAM2
 station-id number 8343147368
 caller-id enable
voice-port 0/0/2
 input gain 2
 no comfort-noise
 cptone MX
 timeouts call-disconnect 2
 connection plar 3001
 station-id name SVAM3
 station-id number 8343147378
 caller-id enable
voice-port 0/0/3
 input gain 2
 no comfort-noise
 cptone MX
 connection plar 2012
 station-id number 8343147394
 caller-id enable
voice-port 0/1/0:0
 echo-cancel coverage 32
 cptone MX
 timeouts interdigit 3
 timeouts call-disconnect 3
 timeouts wait-release 2
voice-port 0/2/0
 signal groundStart
 ring cadence pattern01
 input gain 3
 output attenuation -2
 no echo-cancel enable
 no comfort-noise
 timing hookflash-in 50 0
 caller-id enable
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
dial-peer voice 2 voip
 description VoiceMail
 destination-pattern 3000
 session protocol sipv2
 session target ipv4:192.168.6.253
 dtmf-relay sip-notify
 codec g711ulaw
 no vad
dial-peer voice 10 pots
 description llamadas LOCAL
 destination-pattern 9[1-9]......
 port 0/1/0:0
 forward-digits 7
dial-peer voice 21 pots
 description llamadas LD NACIONAL
 destination-pattern 901..........
 port 0/1/0:0
 forward-digits 12
dial-peer voice 31 pots
 description llamadas CELULAR
 destination-pattern 904[45]..........
 port 0/1/0:0
 forward-digits 13
dial-peer voice 40 pots
 description llamadas LD INTERNACIONAL
 destination-pattern 9001..........
 port 0/1/0:0
 forward-digits 13
dial-peer voice 2011 pots
 destination-pattern 2011
 port 0/2/0
dial-peer voice 52 pots
 destination-pattern 900.T
 port 0/1/0:0
 forward-digits 0
 prefix 00
dial-peer voice 1 voip
 destination-pattern 3001
 codec g711ulaw
 no vad
dial-peer voice 100 voip
 incoming called-number .
 dtmf-relay h245-alphanumeric
 codec g711ulaw
 no vad
dial-peer voice 60 pots
 incoming called-number .T
 direct-inward-dial
num-exp 1001 2004
num-exp 1007 2007
num-exp 1002 2002
num-exp 1003 2001
num-exp 1004 2003
num-exp 1005 2005
num-exp 1006 2006
num-exp 1008 2008
num-exp 1009 2009
num-exp 1011 2011
num-exp 1010 2010
num-exp 1012 2012
num-exp 1013 2013
num-exp 1000 3001
telephony-service
 pin 356287
 max-ephones 25
 max-dn 25
 ip source-address 192.168.6.254 port 2000
 auto assign 1 to 13
 auto assign 1 to 18
 system message SVAM INTERNATIONAL DE MEXICO
 url services http://192.168.6.253/voiceview/common/login.do
 url authentication http://192.168.6.253/voiceview/authentication/authenticate.do
 load 7911 SCCP11.9-0-2SR1S
 time-format 24
 date-format dd-mm-yy
 voicemail 3000
 max-conferences 4 gain -6
 call-forward pattern .T
 moh SVAMPromoAudio.wav
 multicast moh 239.10.16.4 port 16384 route 192.168.8.0
 web admin system name cmeadmin password c15c0123
 dn-webedit
 time-webedit
 transfer-system full-consult
 transfer-pattern .T
 login timeout 1 clear 23:59
 after-hours block pattern 1 9001
 after-hours block pattern 2 904
 after-hours day Sun 00:00 23:59
 after-hours day Mon 00:00 23:59
 after-hours day Tue 00:00 23:59
 after-hours day Wed 00:00 23:59
 after-hours day Thu 00:00 23:59
 after-hours day Fri 00:00 23:59
 after-hours day Sat 00:00 23:59
 create cnf-files version-stamp 7960 Oct 08 2012 17:17:42
ephone-template  1
 softkeys hold  Resume Newcall Select
 softkeys idle  Redial Newcall Login Pickup Gpickup ConfList Dnd
 softkeys ringing  Answer Dnd
ephone-dn  1  dual-line
 number 2001
 label Othon
 name Othon
 call-forward busy 3000
 call-forward noan 3000 timeout 18
ephone-dn  2  dual-line
 number 2002
 label Yesica
 name Yesica
ephone-dn  3  dual-line
 number 2003
 label VideoConf Room
 name VideoConf Room
ephone-dn  4  dual-line
 number 2004
 label Fernando
 name Fernando
ephone-dn  5  dual-line
 number 2005
 label Brenda
 name Brenda
ephone-dn  6  dual-line
 number 2006
 label Julio
 name Julio
 call-forward busy 2016
ephone-dn  7  dual-line
 number 2007
 label Dario
 name Dario
 call-forward noan 3000 timeout 10
ephone-dn  8
 number 2008
 label Meeting Room
 name Meeting Room
 call-forward noan 3000 timeout 20
ephone-dn  9  dual-line
 number 2009
 label Mario
 name Mario
ephone-dn  10  dual-line
 number 2010
 label Jessica
 name Jessica
ephone-dn  11  dual-line
 number 2011
 label Edith
 name Edith
 call-forward all 2012
 call-forward busy 2012
ephone-dn  12  dual-line
 number 2012
 label Santos
 name Santos
ephone-dn  13  dual-line
 number 2013
 label Nancy
 name Nancy
 call-forward busy 2014
ephone-dn  14  dual-line
 number 2014
 label Nora
 name Nora
ephone-dn  15  dual-line
 number 2015
 label Aomori
 name Aomori
 call-forward busy 2017
ephone-dn  16  dual-line
 number 2016
 label Karem
 name Karem
ephone-dn  17  dual-line
 number 2017
 label Shara
 name Shara
ephone-dn  18  dual-line
 number 2018
 label Luz Elena
 name Luz Elena
ephone-dn  20  dual-line
 number 2020
 label Guest
 name Guest
ephone-dn  21  dual-line
 number 2021
 label MeeboxMario
 name MeeboxMario
ephone  1
 after-hours exempt
 username "othon"
ephone  2
 mac-address 0027.0DBF.8E49
 after-hours exempt
 username "videoconfroom"
 type 7942
 button  1:3
 pin 379002
ephone  3
 mac-address C8F9.F969.EA24
 after-hours exempt
 username "yheredia"
 type 7942
 button  1:2
 pin 928133
ephone  4
 mac-address 34BD.C8C7.33AD
 after-hours exempt
 username "fcastaneda"
 type 7942
 button  1:4
 pin 472928
ephone  5
 mac-address 9CAF.CA84.A11C
 username "bmata"
 type 7911
 button  1:5
 pin 289135
ephone  6
 mac-address 9CAF.CA85.4668
 after-hours exempt
 username "jguerrero"
 type 7911
 button  1:6
 pin 373892
ephone  7
 mac-address 9CAF.CA84.F5EF
 username "rsanchez"
 type 7911
 button  1:7
 pin 648103
ephone  8
 mac-address 0027.0DBF.957E
 after-hours exempt
 username "mroom"
 type 7942
 button  1:8
 pin 563820
ephone  9
 mac-address 9CAF.CA84.A17F
 username "mloyola"
 type 7911
 button  1:9
 pin 838920
ephone  10
 mac-address C8F9.F969.F528
 after-hours exempt
 username "jestrella"
 type 7942
 button  1:10
 pin 296421
ephone  11
 mac-address 9CAF.CA85.4646
 username "eruiz"
 type 7911
 button  1:11
 pin 984170
ephone  12
 mac-address 9CAF.CA85.473A
 username "smarin"
 type 7911
 button  1:12
 pin 985473
ephone  13
 no phone-ui speeddial-fastdial
 no phone-ui snr
 mac-address 9CAF.CA84.F620
 after-hours exempt
 username "ngarcia"
 type 7911
 button  1:13
 pin 984620
ephone  14
 mac-address 0817.35D4.69AB
 username "knight"
 type 7911
 button  1:14
 pin 123456
ephone  15
 mac-address 0019.56D3.5DBA
 username "acamero"
 type 7911
 button  1:15
 pin 123456
ephone  16
 mac-address 0025.8416.774C
 username "kvazquez"
 type 7911
 button  1:16
 pin 123456
ephone  17
 mac-address 0019.AA29.09E7
 username "nmartinez"
 type 7911
 button  1:17
 pin 123456
ephone  18
 mac-address 0024.C444.A977
 username "arosales"
 type 7911
 button  1:18
 pin 123456
ephone  20
 mac-address 9CAF.CA85.0630
 username "Guest"
 type 7911
 button  1:20
 pin 123456
ephone  21
 mac-address C485.08E8.85FA
 username "MarioMeebox"
 type CIPC
 button  1:21
 pin 123456
line con 0
 exec-timeout 0 0
 logging synchronous
line aux 0
line 66
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
 login local
 transport input telnet ssh
scheduler allocate 20000 1000
end
This is the result of debug voip ccapi inout when a call is not complete.
Jul 21 16:12:56.975: //-1/B6371AC69148/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   cisco-ani=2006
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Jul 21 16:12:56.975: //-1/B6371AC69148/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x67935488, Call Info(
   Calling Number=2006,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
   Incoming Dial-peer=20006, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Jul 21 16:12:56.975: //-1/B6371AC69148/CCAPI/ccCheckClipClir:
   In: Calling Number=2006(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=2006(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Jul 21 16:12:56.975: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jul 21 16:12:56.975: :cc_get_feature_vsa malloc success
Jul 21 16:12:56.979: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jul 21 16:12:56.979:  cc_get_feature_vsa count is 3
Jul 21 16:12:56.979: :FEATURE_VSA attributes are: feature_name:0,feature_time:1703569976,feature_id:2329
Jul 21 16:12:56.979: //1503/B6371AC69148/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=2006(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown))
Jul 21 16:12:56.979: //1503/B6371AC69148/CCAPI/cc_process_call_setup_ind:
   Event=0x66D465C8
Jul 21 16:12:56.979: //1503/B6371AC69148/CCAPI/ccCallSetContext:
   Context=0x658AFF94
   >>>>CCAPI handed cid 1503 with tag 20006 to app "_ManagedAppProcess_Default"
Jul 21 16:12:56.983: //1503/B6371AC69148/CCAPI/ccCallSetupAck:
   Call Id=1503
Jul 21 16:12:56.983: //1503/B6371AC69148/CCAPI/cc_api_set_transfer_info:
   Transfer Number=, Transfer Reason=0x0
Jul 21 16:12:56.983: //1503/B6371AC69148/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=TRUE, Tone=Dial Tone,
   Tone Direction=Network, Params=0x0, Call Id=1503
Jul 21 16:12:56.983: //1503/B6371AC69148/CCAPI/ccSetDigitTimeouts:
   Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
   Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
Jul 21 16:12:56.983: //1503/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
   (callID=0x5DF, digit_event=0x1, enable=TRUE, consume=FALSE)
Jul 21 16:12:56.983: //1503/B6371AC69148/CCAPI/ccCallReportDigits:
   Enabled=TRUE, Call Id=1503
Jul 21 16:12:56.987: //1503/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x67935488, callID=0x5DF, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Jul 21 16:12:56.987: //1503/B6371AC69148/CCAPI/cc_api_call_report_digits_done:
   Enabled=TRUE, Disposition=0x0, Interface=0x67935488, Call Id=1503
Jul 21 16:13:00.803: //1503/B6371AC69148/CCAPI/cc_api_call_digit_begin:
   Source Call Id=1503, Digit=9, DigitBeginFlags=0x0,
   Rtp Timestamp=0xD84B18, Rtp Expiration=0x0
Jul 21 16:13:00.803: //1503/B6371AC69148/CCAPI/cc_api_call_digit_end:
   Source Call Id=1503, Digit=9, Duration=100,
Jul 21 16:13:01.167: //1503/B6371AC69148/CCAPI/cc_api_call_digit_begin:
   Source Call Id=1503, Digit=1, DigitBeginFlags=0x0,
   Rtp Timestamp=0xD8C818, Rtp Expiration=0x0
Jul 21 16:13:01.167: //1503/B6371AC69148/CCAPI/cc_api_call_digit_end:
   Source Call Id=1503, Digit=1, Duration=100,
Jul 21 16:13:01.455: //1503/B6371AC69148/CCAPI/cc_api_call_digit_begin:
   Source Call Id=1503, Digit=0, DigitBeginFlags=0x0,
   Rtp Timestamp=0xD94518, Rtp Expiration=0x0
Jul 21 16:13:01.455: //1503/B6371AC69148/CCAPI/cc_api_call_digit_end:
   Source Call Id=1503, Digit=0, Duration=100,
Jul 21 16:13:01.659: //1503/B6371AC69148/CCAPI/cc_api_call_digit_begin:
   Source Call Id=1503, Digit=7, DigitBeginFlags=0x0,
   Rtp Timestamp=0xD9C218, Rtp Expiration=0x0
Jul 21 16:13:01.659: //1503/B6371AC69148/CCAPI/cc_api_call_digit_end:
   Source Call Id=1503, Digit=7, Duration=100,
Jul 21 16:13:01.891: //1503/B6371AC69148/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0xDA3F18, Rtp Expiration=0x0
Jul 21 16:13:01.891: //1503/B6371AC69148/CCAPI/cc_api_call_digit_end:
Jul 21 16:13:02.179: //1503/B6371AC69148/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0xDABC18, Rtp Expiration=0x0
Jul 21 16:13:02.179: //1503/B6371AC69148/CCAPI/cc_api_call_digit_end:
Jul 21 16:13:02.439: //1503/B6371AC69148/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0xDB3918, Rtp Expiration=0x0
Jul 21 16:13:02.439: //1503/B6371AC69148/CCAPI/cc_api_call_digit_end:
Jul 21 16:13:02.575: //1503/B6371AC69148/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0xDBB618, Rtp Expiration=0x0
Jul 21 16:13:02.575: //1503/B6371AC69148/CCAPI/cc_api_call_digit_end:
Jul 21 16:13:02.579: //1503/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
   (callID=0x5DF, digit_event=0x0, enable=FALSE, consume=FALSE)
Jul 21 16:13:02.579: //1503/B6371AC69148/CCAPI/ccCallReportDigits:
Jul 21 16:13:02.579: //1503/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x67935488, callID=0x5DF, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
Jul 21 16:13:02.579: //1503/B6371AC69148/CCAPI/cc_api_call_report_digits_done:
Jul 21 16:13:02.579: //1503/B6371AC69148/CCAPI/ccCallProceeding:
Jul 21 16:13:02.583: //1503/B6371AC69148/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=10, Params=0x658BF74C, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Jul 21 16:13:02.583: //1503/B6371AC69148/CCAPI/ccCheckClipClir:
   Destination Pattern=9[1-9]......, Called Number=91071000, Digit Strip=TRUE
   Called Number=91071000(TON=Unknown, NPI=Unknown),
   Guid=B6371AC6-1028-11E4-9148-D9073BD41B29, Outgoing Dial-peer=10
Jul 21 16:13:02.587: //1503/B6371AC69148/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=2006
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=91071000
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Jul 21 16:13:02.587: //1503/B6371AC69148/CCAPI/ccIFCallSetupRequestPrivate:
   Call Params(Calling Number=2006,(Calling Name=Julio)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=91071000(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-peer=10, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Jul 21 16:13:02.587: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jul 21 16:13:02.587: :cc_get_feature_vsa malloc success
Jul 21 16:13:02.587:  cc_get_feature_vsa count is 4
Jul 21 16:13:02.587: :FEATURE_VSA attributes are: feature_name:0,feature_time:1703569752,feature_id:2330
Jul 21 16:13:02.587: //1504/B6371AC69148/CCAPI/ccIFCallSetupRequestPrivate:
Jul 21 16:13:02.587: //1504/B6371AC69148/CCAPI/ccCallSetContext:
   Context=0x658BF6FC
Jul 21 16:13:02.587: //1503/B6371AC69148/CCAPI/ccSaveDialpeerTag:
Jul 21 16:13:10.591: //1504/B6371AC69148/CCAPI/cc_api_call_disconnected:
   Cause Value=41, Interface=0x6623758C, Call Id=1504
Jul 21 16:13:10.591: //1503/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
Jul 21 16:13:10.591: //1504/B6371AC69148/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=1504
Jul 21 16:13:10.591: //1504/B6371AC69148/CCAPI/ccCallDisconnect:
   Cause Value=41, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=41)
Jul 21 16:13:10.591: //1504/B6371AC69148/CCAPI/cc_api_get_transfer_info:
Jul 21 16:13:10.595: //1504/B6371AC69148/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x6623758C, Tag=0x0, Call Id=1504,
Jul 21 16:13:10.595: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 21 16:13:10.595: :cc_free_feature_vsa freeing 658A6950
Jul 21 16:13:10.595:  vsacount in free is 3
Jul 21 16:13:10.599: //1503/B6371AC69148/CCAPI/ccCallDisconnect:
   Cause Value=41, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Jul 21 16:13:10.599: //1503/B6371AC69148/CCAPI/cc_api_get_transfer_info:
Jul 21 16:13:18.251: //1503/B6371AC69148/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x67935488, Tag=0x0, Call Id=1503,
Jul 21 16:13:18.251: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 21 16:13:18.251: :cc_free_feature_vsa freeing 658A6A30
Jul 21 16:13:18.251:  vsacount in free is 2
Hi Julio,
The debugs for the ccapi layer show that the Setup request was successful at 16:13:02 after matching the outbound dial peer 10.
However, it disconnects the call at 16:13:10, approximately 8 seconds later.
Could you please run the same debugs again for a test call, along with the debugs showing interaction with the Provider.
If you are using PRI, run (debug isdn q931),
If you using SIP, use (debug ccsip message)
I wanted to check if there is an issue with the provider's circuit and sending the disconnect.
HTH,
Jagpreet Singh Barmi
Hi, This is the result with debug ccsip message command enabled:
Jul 21 17:50:10.355: //1567/47A9EDA99202/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=10, Params=0x658B12EC, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Jul 21 17:50:10.355: //1567/47A9EDA99202/CCAPI/ccCheckClipClir:
   Guid=47A9EDA9-1036-11E4-9202-D9073BD41B29, Outgoing Dial-peer=10
Jul 21 17:50:10.355: //1567/47A9EDA99202/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=2006
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=91071000
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Jul 21 17:50:10.359: //1567/47A9EDA99202/CCAPI/ccIFCallSetupRequestPrivate:
Jul 21 17:50:10.359: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jul 21 17:50:10.359: :cc_get_feature_vsa malloc success
Jul 21 17:50:10.359:  cc_get_feature_vsa count is 2
Jul 21 17:50:10.359: :FEATURE_VSA attributes are: feature_name:0,feature_time:1741826608,feature_id:2409
Jul 21 17:50:10.359: //1568/47A9EDA99202/CCAPI/ccIFCallSetupRequestPrivate:
Jul 21 17:50:10.359: //1568/47A9EDA99202/CCAPI/ccCallSetContext:
   Context=0x658B129C
Jul 21 17:50:10.359: //1567/47A9EDA99202/CCAPI/ccSaveDialpeerTag:
Jul 21 17:50:18.363: //1568/47A9EDA99202/CCAPI/cc_api_call_disconnected:
   Cause Value=41, Interface=0x6623758C, Call Id=1568
Jul 21 17:50:18.363: //1567/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
Jul 21 17:50:18.363: //1568/47A9EDA99202/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=1568
Jul 21 17:50:18.363: //1568/47A9EDA99202/CCAPI/ccCallDisconnect:
Jul 21 17:50:18.363: //1568/47A9EDA99202/CCAPI/cc_api_get_transfer_info:
Jul 21 17:50:18.367: //1568/47A9EDA99202/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x6623758C, Tag=0x0, Call Id=1568,
Jul 21 17:50:18.367: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 21 17:50:18.367: :cc_free_feature_vsa freeing 67D22A28
Jul 21 17:50:18.367:  vsacount in free is 1
Jul 21 17:50:18.371: //1567/47A9EDA99202/CCAPI/ccCallDisconnect:
Jul 21 17:50:18.371: //1567/47A9EDA99202/CCAPI/cc_api_get_transfer_info:
Jul 21 17:50:27.427: %ENVMON-4-FAN_LOW_RPM: Fan 2 service recommended
Jul 21 17:50:28.815: //1567/47A9EDA99202/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x67935488, Tag=0x0, Call Id=1567,
Jul 21 17:50:28.815: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 21 17:50:28.815: :cc_free_feature_vsa freeing 67D22B08
Jul 21 17:50:28.815:  vsacount in free is 0
Hi Julio,
I think you mis-read my post earlier.
--Jagpreet Singh Barmi
Hi Jagpreet,
I did the test running debug voip ccapi inout and debug ccsip message. When a call is not complete I don´t get any messages related with interaction with Provider, the output is the same like the ones I posted earlier.
When a call is complete there are messages showing interaction with Provider, this is the output:
Jul 22 09:32:43.787: //1638/F7A4AA3892D0/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=8341071000
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=3001
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Jul 22 09:32:43.787: //1638/F7A4AA3892D0/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x6690D90C, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=8341071000,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=3001(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=1, Call Count On=FALSE,
   Sub Calling(TON=Unknown, NPI=Unknown, Data=-`f`f`, Length=102)
   Sub Called(TON=Abbreviated, NPI=Unknown, Data=AXf`, Length=96)
Jul 22 09:32:43.787: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jul 22 09:32:43.787: :cc_get_feature_vsa malloc success
Jul 22 09:32:43.787:  cc_get_feature_vsa count is 7
Jul 22 09:32:43.787: :FEATURE_VSA attributes are: feature_name:0,feature_time:1723399680,feature_id:2507
Jul 22 09:32:43.791: //1639/F7A4AA3892D0/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
Jul 22 09:32:43.791: //1639/F7A4AA3892D0/CCAPI/ccCallSetContext:
   Context=0x658B84CC
Jul 22 09:32:43.791: //1638/F7A4AA3892D0/CCAPI/ccSaveDialpeerTag:
Jul 22 09:32:43.795: //1639/F7A4AA3892D0/CCAPI/cc_api_call_proceeding:
   Interface=0x6690D90C, Progress Indication=NULL(0)
Jul 22 09:32:43.799: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:3001@192.168.6.253:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.6.254:5060;branch=z9hG4bK246231F
Remote-Party-ID: <sip:8341071000@192.168.6.254>;party=calling;screen=no;privacy=off
From: <sip:8341071000@192.168.6.254>;tag=19276D30-1E89
To: <sip:3001@192.168.6.253>
Date: Tue, 22 Jul 2014 09:32:43 GMT
Call-ID: F7A85328-10B911E4-92D5D907-3BD41B29@192.168.6.254
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 4154763832-280564196-2463160583-1003756329
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1406021563
Contact: <sip:8341071000@192.168.6.254:5060>
Call-Info: <sip:192.168.6.254:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 194
v=0
o=CiscoSystemsSIP-GW-UserAgent 4979 6723 IN IP4 192.168.6.254
s=SIP Call
c=IN IP4 192.168.6.254
t=0 0
m=audio 17022 RTP/AVP 0
a=rtpmap:0 PCMU/8000
a=ptime:20
Jul 22 09:32:43.815: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <sip:3001@192.168.6.253>;tag=cuee3b094e8
CSeq: 101 INVITE
Content-Length: 0
Contact: <sip:3001@192.168.6.253:5060>
Jul 22 09:32:43.851: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
CSeq: 101 INVITE
Content-Length: 0
Jul 22 09:32:43.855: //1639/F7A4AA3892D0/CCAPI/cc_api_call_alert:
   Interface=0x6690D90C, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Jul 22 09:32:43.855: //1638/F7A4AA3892D0/CCAPI/ccCallAlert:
Jul 22 09:32:43.895: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Content-Length: 180
Call-Info: <sip:192.168.6.253:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
v=0
o=CiscoSystemsSIP-Workflow-App-UserAgent 3501 3501 IN IP4 192.168.6.253
s=SIP Call
c=IN IP4 192.168.6.253
t=0 0
m=audio 16904 RTP/AVP 0
a=rtpmap:0 pcmu/8000
a=ptime:20
Jul 22 09:32:43.899: //1639/F7A4AA3892D0/CCAPI/cc_api_call_connected:
   Interface=0x6690D90C, Data Bitmask=0x1, Progress Indication=NULL(0),
   Connection Handle=0
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Jul 22 09:32:43.903: //1638/F7A4AA3892D0/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Network, Params=0x0, Call Id=1638
Jul 22 09:32:43.903: //1638/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x65865358, callID1=0x666, callID2=0x667, tag=0x0)
   (confID=0x65865358, callID1=0x666, gcid=F7A4AA38-10B911E4-92D0D907-3BD41B29, tag=0x0)
Jul 22 09:32:43.903: //1639/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x65865358, callID2=0x667, gcid=F7A4AA38-10B911E4-92D0D907-3BD41B29, tag=0x0)
Jul 22 09:32:43.903: //1638/F7A4AA3892D0/CCAPI/ccConferenceCreate:
   Conference Id=0x65865358, Call Id1=1638, Call Id2=1639, Tag=0x0
Jul 22 09:32:43.903: //1638/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x187, Source Interface=0x6623758C, Source Call Id=1638,
   Destination Call Id=1639, Disposition=0x0, Tag=0xFFFFFFFF
Jul 22 09:32:43.903: //1639/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Jul 22 09:32:43.903: cc_api_get_xcode_stream : 4534
Jul 22 09:32:43.903: //1639/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x187, Source Interface=0x6690D90C, Source Call Id=1639,
   Destination Call Id=1638, Disposition=0x0, Tag=0x0
Jul 22 09:32:43.907: //1638/F7A4AA3892D0/CCAPI/cc_generic_bridge_done:
Jul 22 09:32:43.907: //1638/F7A4AA3892D0/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x187, Destination Call Id=1639)
Jul 22 09:32:43.907: //1639/F7A4AA3892D0/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x187, Destination Call Id=1638)
Jul 22 09:32:43.907: //1638/F7A4AA3892D0/CCAPI/cc_api_caps_ind:
   Destination Interface=0x6690D90C, Destination Call Id=1639, Source Call Id=1638,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
Jul 22 09:32:43.907: //1639/F7A4AA3892D0/CCAPI/cc_api_caps_ind:
   Destination Interface=0x6623758C, Destination Call Id=1638, Source Call Id=1639,
   Modem=0x0, Codec Bytes=160, Signal Type=2)
Jul 22 09:32:43.907: //1639/F7A4AA3892D0/CCAPI/cc_api_caps_ack:
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=4341)
Jul 22 09:32:43.907: //1638/F7A4AA3892D0/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x187, Call Id1=1638, Call Id2=1639
Jul 22 09:32:43.911: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:3001@192.168.6.253:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.6.254:5060;branch=z9hG4bK24787
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Jul 22 09:32:43.911: //1638/F7A4AA3892D0/CCAPI/ccCallConnect:
   Progress Indication=NULL(0), Data Bitmask=0x1
   Call Entry(Connected=TRUE, Responsed=TRUE)
Jul 22 09:32:44.991: //1638/F7A4AA3892D0/CCAPI/cc_api_caps_ack:
Jul 22 09:32:44.995: //1638/F7A4AA3892D0/CCAPI/cc_api_voice_mode_event:
   Call Id=1638
   Call Entry(Context=0x658B71C4)
Jul 22 09:32:45.139: //1637/EF90CC4292C9/CCAPI/cc_api_call_alert:
   Interface=0x6623758C, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1)
Jul 22 09:32:45.139: //1637/EF90CC4292C9/CCAPI/cc_api_call_connected:
   Interface=0x6623758C, Data Bitmask=0x1, Progress Indication=DESTINATION IS NON ISDN(2),
   Connection Handle=0
Jul 22 09:32:45.143: //1636/EF90CC4292C9/CCAPI/ccCallAlert:
Jul 22 09:32:45.143: //1636/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x65865550, callID1=0x664, callID2=0x665, tag=0x0)
   (confID=0x65865550, callID1=0x664, gcid=EF90CC42-10B911E4-92C9D907-3BD41B29, tag=0x0)
Jul 22 09:32:45.143: //1637/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x65865550, callID2=0x665, gcid=EF90CC42-10B911E4-92C9D907-3BD41B29, tag=0x0)
Jul 22 09:32:45.143: //1636/EF90CC4292C9/CCAPI/ccConferenceCreate:
   Conference Id=0x65865550, Call Id1=1636, Call Id2=1637, Tag=0x0
Jul 22 09:32:45.143: //1636/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x188, Source Interface=0x67935488, Source Call Id=1636,
   Destination Call Id=1637, Disposition=0x0, Tag=0xFFFFFFFF
Jul 22 09:32:45.143: //1637/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x188, Source Interface=0x6623758C, Source Call Id=1637,
   Destination Call Id=1636, Disposition=0x0, Tag=0xFFFFFFFF
Jul 22 09:32:45.143: //1636/EF90CC4292C9/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x188, Destination Call Id=1637)
Jul 22 09:32:45.143: //1637/EF90CC4292C9/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x188, Destination Call Id=1636)
Jul 22 09:32:45.147: //1636/EF90CC4292C9/CCAPI/cc_api_caps_ind:
   Destination Interface=0x6623758C, Destination Call Id=1637, Source Call Id=1636,
Jul 22 09:32:45.147: //1637/EF90CC4292C9/CCAPI/cc_api_caps_ind:
   Destination Interface=0x67935488, Destination Call Id=1636, Source Call Id=1637,
Jul 22 09:32:45.147: //1637/EF90CC4292C9/CCAPI/cc_api_caps_ack:
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=5197)
Jul 22 09:32:45.147: //1636/EF90CC4292C9/CCAPI/cc_api_caps_ack:
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=2949)
Jul 22 09:32:45.151: //1636/EF90CC4292C9/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x188, Call Id1=1636, Call Id2=1637
Jul 22 09:32:45.151: //1636/EF90CC4292C9/CCAPI/cc_api_voice_mode_event:
   Call Id=1636
   Call Entry(Context=0x658B97D4)
Jul 22 09:32:45.159: //1636/EF90CC4292C9/CCAPI/ccCallConnect:
   Progress Indication=DESTINATION IS NON ISDN(2), Data Bitmask=0x1
Jul 22 09:32:45.159: //1636/EF90CC4292C9/CCAPI/ccCallFeature:
   Feature Type=25, Call Id=1636
Jul 22 09:32:45.159: //1637/EF90CC4292C9/CCAPI/cc_api_voice_mode_event:
   Call Id=1637
   Call Entry(Context=0x658B38AC)
Jul 22 09:32:50.235: %ENVMON-4-FAN_LOW_RPM: Fan 2 service recommended
Jul 22 09:33:15.183: //1636/EF90CC4292C9/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x67935488, Call Id=1636
Jul 22 09:33:15.187: //1636/EF90CC4292C9/CCAPI/ccConferenceDestroy:
   Conference Id=0x188, Tag=0x0
Jul 22 09:33:15.187: //1636/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=1637, Disposition=0x0, Tag=0x0
Jul 22 09:33:15.187: //1637/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=1636, Disposition=0x0, Tag=0x0
Jul 22 09:33:15.187: //1636/EF90CC4292C9/CCAPI/cc_generic_bridge_done:
Jul 22 09:33:15.191: //1636/EF90CC4292C9/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Jul 22 09:33:15.191: //1636/EF90CC4292C9/CCAPI/cc_api_get_transfer_info:
Jul 22 09:33:15.191: //1637/EF90CC4292C9/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Jul 22 09:33:15.191: //1637/EF90CC4292C9/CCAPI/cc_api_get_transfer_info:
Jul 22 09:33:15.195: //1636/EF90CC4292C9/CCAPI/cc_api_call_feature:
   Feature Type=6, Interface=0x67935488, Call Id=1636
Jul 22 09:33:15.207: //1636/EF90CC4292C9/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x67935488, Tag=0x0, Call Id=1636,
Jul 22 09:33:15.207: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 22 09:33:15.207: :cc_free_feature_vsa freeing 66B90178
Jul 22 09:33:15.207:  vsacount in free is 6
Jul 22 09:33:15.355: //1637/EF90CC4292C9/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x6623758C, Tag=0x0, Call Id=1637,
Jul 22 09:33:15.355: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 22 09:33:15.355: :cc_free_feature_vsa freeing 66B90258
Jul 22 09:33:15.355:  vsacount in free is 5
Jul 22 09:33:17.703: //1638/F7A4AA3892D0/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x6623758C, Call Id=1638
Jul 22 09:33:17.703: //1638/F7A4AA3892D0/CCAPI/ccConferenceDestroy:
   Conference Id=0x187, Tag=0x0
Jul 22 09:33:17.703: //1638/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=1639, Disposition=0x0, Tag=0x0
Jul 22 09:33:17.703: //1639/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Jul 22 09:33:17.703: //1638/F7A4AA3892D0/CCAPI/cc_generic_bridge_done:
Jul 22 09:33:17.703: //1638/F7A4AA3892D0/CCAPI/ccCallDisconnect:
Jul 22 09:33:17.707: //1638/F7A4AA3892D0/CCAPI/ccCallDisconnect:
Jul 22 09:33:17.707: //1638/F7A4AA3892D0/CCAPI/cc_api_get_transfer_info:
Jul 22 09:33:17.707: //1639/F7A4AA3892D0/CCAPI/ccCallDisconnect:
Jul 22 09:33:17.715: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:3001@192.168.6.253:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.6.254:5060;branch=z9hG4bK2486D0
Max-Forwards: 70
Timestamp: 1406021597
CSeq: 102 BYE
Reason: Q.850;cause=16
Content-Length: 0
Jul 22 09:33:17.739: //1638/F7A4AA3892D0/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x6623758C, Tag=0x0, Call Id=1638,
Jul 22 09:33:17.739: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 22 09:33:17.739: :cc_free_feature_vsa freeing 66B8FED8
Jul 22 09:33:17.739:  vsacount in free is 4
Jul 22 09:33:17.747: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 BYE
Content-Length: 0
Jul 22 09:33:17.747: //1639/F7A4AA3892D0/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x6690D90C, Tag=0x0, Call Id=1639,
Jul 22 09:33:17.751: //1639/F7A4AA3892D0/CCAPI/cc_api_call_disconnect_done:
Jul 22 09:33:17.751: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 22 09:33:17.751: :cc_free_feature_vsa freeing 66B8FDF8
Jul 22 09:33:17.751:  vsacount in free is 3
Jul 22 09:33:20.247: %ENVMON-4-FAN_LOW_RPM: Fan 2 service recommended
CME#
