How can I set the number of digits for Call Transfer in CUCM?
Hi guys,
I've just installed a 9.1 CUCM and I can´t get the phones (6921) to Trnsfer calls of 4 digit DNs. I can just get to transfer 3 digit numbers. Where can I change this? I haven't found the option yet.
Thanks in advance!
Jaime Valencia
There's no such option, you just use the same CSS as the line/device has when making a transfer.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jaime Valencia
java
java
Thank you for yor answer Jaime.
I don't know what I'm doing wrong on this particular cucm set up. The thing is that I can transfer the call with 3 digits, but I can´t do it with 4 digits. I don´t see how the CSS can affect that (I´m using the appropiate CSS).
I suspect overlapping dial plan. Do you have overlapping dial plan.
What does DNA shous result for the 4 digit number.
regards
Ronak Patel
Rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Thanks so much for your answers Jaime and Ronak.
I´ve finally figure it out. I had one phone with the wrong CSS (I guess I overlooked at this huge detail and assumed I had it well configured).
Best Regards
