How do I assign a telephone number to a Cisco IP Communicator 7.0.3.3 softphone?
I have just downloaded and installed the "Cisco IP Communicator 7.0.3.3" softphone, and I can see that it has been assigned the telephone number 6651478.
How do I change this in our "Cisco Unified CM Administration - System version 7.0.1.11000-2", so I can assign my current number 1595 to my softphone instead?
Kind regards,
Carl-Marius
Adrian Saavedra
Level 7
Level 7
Here you have how to configure a Directory Number, from the Admin Guide:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_0_1/ccmcfg/b03dn.html#wp1281526
Hope to help.
-- Adrián.
Adrian Saavedra
Level 7
Level 7
Hope to help.
-- Adrián.
Hi Adrián,
That was precisely what I was looking for! Thank you very much!
Kind regards,
Carl-Marius
Jaime Valencia
Go to the IPC DN page and change it
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
