02-02-2016 02:30 AM - edited 03-17-2019 05:42 AM
Hi All,
How do I cancel (force revert) a "call pickup" call.
Let me elaborate. At the moment I have Call Pickup configured for the team.
A person can "Call Pickup" another phone ringing, at this point the call starts ringing on their phone.
I can see who the caller is and for whom the call was for. If I don't want to answer the call I have to let it ring out (Call Pickup No Answer Timer minimum is 12 seconds) so the call goes back to the original phone.
How can I preempt that by for example having a softkey which says "Cancel" or something similar.
Any ideas anyone? Happy to give more details if that helps
Background:
Using CUCM 8.6.2 on SCCP phones
Phone Types: 7945, 7942
Thanks in advance
Solved! Go to Solution.
02-02-2016 03:09 AM
Hi.
This cannot be done but what you can do is to enable "calling party and called party information" notification on call pickup group configuration page.
In this way you'll be notified what is the calling and called party numbers before you pickup the call and decide if you want to pickup or not.
Carlo
02-02-2016 03:06 AM
I am not aware about such option. The call has to revert back to original called endpoint
02-02-2016 03:09 AM
Hi.
Carlo
02-02-2016 03:29 AM
Thanks Carlo,
This does address the issue raised. So at least in my case I will say it is correct answer.
Thanks for that :-)
