09-11-2014 09:15 AM - edited 03-17-2019 12:07 AM
I use the show line command and it shows:
dsx1(slot/unit/channel)=3/0/15, status=VDEV_STATUS_ACTIVE_CALL.VDEV_STATUS_NEGOTIATED.
but when i do show isdn status the b-channel 15 does not show as having an active layer 3 call. Is there some wierd numbering scheme? How do I find out which b-channel a tty line is using?
09-11-2014 10:51 AM
Use "show voice call status" command.
Chris
09-11-2014 11:37 AM
Hmm, that doesn't seem to work. When I do show isdn status I get:
Global ISDN Switchtype = primary-dms100
ISDN Serial3/0:23 interface
dsl 0, interface ISDN Switchtype = primary-dms100
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
8 Active Layer 3 Call(s)
CCB:callid=801E, sapi=0, ces=0, B-chan=23, calltype=VOICE
CCB:callid=807A, sapi=0, ces=0, B-chan=20, calltype=VOICE
CCB:callid=80AC, sapi=0, ces=0, B-chan=19, calltype=VOICE
CCB:callid=80BA, sapi=0, ces=0, B-chan=21, calltype=VOICE
CCB:callid=80C5, sapi=0, ces=0, B-chan=22, calltype=VOICE
CCB:callid=80CE, sapi=0, ces=0, B-chan=18, calltype=VOICE
CCB:callid=80E7, sapi=0, ces=0, B-chan=17, calltype=VOICE
CCB:callid=80FF, sapi=0, ces=0, B-chan=16, calltype=VOICE
Active dsl 0 CCBs = 8
The Free Channel Mask: 0x80007FFF
Number of L2 Discards = 0, L2 Session ID = 2
for the active serial interface but when I do show voice call status I get:
CallID CID ccVdb Port Slot/DSP:Ch Called # Codec Dial-peers
No active calls found
There are 3 users on tty ports, two show:
dsx1(slot/unit/channel)=NONE, status=VDEV_STATUS_UNLOCKED
for the show line command but one shows:
I want to clear the channels that aren't actually in use but not ones that are. These are not actually voice calls but calls to modems that I think sometimes don't get the ath command sent.
09-11-2014 01:04 PM
Hi.
Do you have configured TTY on your Voice gateway?
If yes please post your config here.
And if show voice call status doesn't give any output while show isdn status or show isdn active give some output, probably they are all TTY sessions.
Let us know
Carlo
09-11-2014 03:17 PM
Not sure what you mean "Do you have configured TTY on your Voice gateway?".
I am using DDR dialer profiles:
interface Serial3/0:23
no ip address
encapsulation ppp
dialer pool-member 1
isdn switch-type primary-dms100
isdn incoming-voice modem
isdn map address *.* plan isdn type national
isdn outgoing display-ie
no cdp enable
interface Dialer1
no ip address
encapsulation ppp
dialer pool 1
dialer idle-timeout 3600
dialer-group 1
no cdp enable
ppp authentication chap
ppp multilink
interface Group-Async0
ip unnumbered GigabitEthernet0/0
encapsulation ppp
no ip mroute-cache
dialer in-band
dialer-group 1
async dynamic address
async mode interactive
peer default ip address pool dyn_pool
compress mppc
ppp pfc remote ignore
ppp acfc remote ignore
ppp callback accept
ppp multilink
group-range 1/00 1/59
routing dynamic
line 1/00 1/59
session-timeout 60
exec-timeout 15 0
script modem-off-hook offhook
script callback callback
no modem InOut
rotary 1 queued
no exec
transport preferred none
transport input ssh
transport output telnet
escape-character NONE
autoselect during-login
autoselect ppp
autohangup
09-11-2014 03:42 PM
What I meant is if you are using your T1 for data calls.
Can you please share a show isdn active detail and a show line?
Carlo
09-12-2014 10:15 AM
Yes I am using the circuit for data calls. It is an ISDN PRI - T1
as5350xm#show isdn active
ISDN ACTIVE CALLS
Call Calling Called Remote Seconds Seconds Seconds Charges
Type Number Number Name Used Left Idle Units/Currency
Out ---N/A--- +1234567890 3 Unavail - 0
as5350xm#sh isdn status
Layer 1 Status:
ACTIVE
Layer 2 Status:
Layer 3 Status:
10 Active Layer 3 Call(s)
CCB:callid=8116, sapi=0, ces=0, B-chan=15, calltype=VOICE
CCB:callid=8134, sapi=0, ces=0, B-chan=17, calltype=VOICE
CCB:callid=8135, sapi=0, ces=0, B-chan=16, calltype=VOICE
CCB:callid=8136, sapi=0, ces=0, B-chan=14, calltype=VOICE
Active dsl 0 CCBs = 10
The Free Channel Mask: 0x80001FFF
as5350xm#who
Line User Host(s) Idle Location
* 2 vty 0 xxxxxxxx idle 00:00:00 172.16.3.2
tty 1/06 yyyyyyyy incoming 00:03:45 172.16.3.2
tty 1/07 zzzzzzz incoming 00:00:00 172.16.3.2
tty 1/09 aaaaaaa incoming 00:00:01 172.16.3.2
Interface User Mode Idle Peer Address
as5350xm#sh line 1/06
Tty Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns Int
* 1/06 Digital modem - - 1 - - 84 2 0/0 -
Line 1/06, Location: "", Type: "xterm"
Length: 65 lines, Width: 237 columns
Status: Ready, Connected, Active, Notify Process
Capabilities: EXEC Suppressed, Hardware Flowcontrol In,
Hardware Flowcontrol Out, Line usable as async interface,
Hangup on Last Close, Integrated Modem, Async Queueing
Modem state: Ready
modem(slot/port)=1/6, state=CONNECTED
dsx1(slot/unit/channel)=3/0/16, status=VDEV_STATUS_ACTIVE_CALL.VDEV_STATUS_NEGOTIATED.
Modem hardware state: DTR DCD* CTS RTS*
Group codes: 0
Special Chars: Escape Hold Stop Start Disconnect Activation
none none - - none
Timeouts: Idle EXEC Idle Session Modem Answer Session Dispatch
00:15:00 01:00:00 none not set
Idle Session Disconnect Warning
never
Login-sequence User Response
00:00:30
Autoselect Initial Wait
not set
Modem type is unknown.
Session limit is not set.
Time since activation: 01:07:37
Editing is enabled.
History is enabled, history size is 20.
DNS resolution in show commands is enabled
Full user help is disabled
Allowed input transports are ssh.
Allowed output transports are telnet.
Preferred transport is none.
No output characters are padded
No special data dispatching characters
as5350xm#sh line 1/07
* 1/07 Digital modem - - 1 - - 38 3 0/0 -
Line 1/07, Location: "", Type: "ibm3151"
Length: 25 lines, Width: 80 columns
Modem state: Ready
modem(slot/port)=1/7, state=CONNECTED
Group codes: 0
none none - - none
never
00:00:30
not set
Time since activation: 01:46:18
Editing is enabled.
as5350xm#sh line 1/09
* 1/09 Digital modem - - 1 - - 26 1 0/0 -
Line 1/09, Location: "", Type: "vt100"
Length: 36 lines, Width: 120 columns
Modem state: Ready
modem(slot/port)=1/9, state=CONNECTED
dsx1(slot/unit/channel)=3/0/13, status=VDEV_STATUS_ACTIVE_CALL.VDEV_STATUS_NEGOTIATED.
Group codes: 0
none none - - none
never
00:00:30
not set
Time since activation: 00:02:20
Editing is enabled.
