How do I find out which PRI b-channel a tty line is using?
tbowen555
I use the show line command and it shows:
dsx1(slot/unit/channel)=3/0/15, status=VDEV_STATUS_ACTIVE_CALL.VDEV_STATUS_NEGOTIATED.
but when i do show isdn status the b-channel 15 does not show as having an active layer 3 call.  Is there some wierd numbering scheme?  How do I find out which b-channel a tty line is using?
6 Replies 6
Chris Deren
Use "show voice call status" command.
Chris
Hmm, that doesn't seem to work. When I do show isdn status I get:
Global ISDN Switchtype = primary-dms100
ISDN Serial3/0:23 interface
        dsl 0, interface ISDN Switchtype = primary-dms100
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
    Layer 3 Status:
        8 Active Layer 3 Call(s)
        CCB:callid=801E, sapi=0, ces=0, B-chan=23, calltype=VOICE
        CCB:callid=807A, sapi=0, ces=0, B-chan=20, calltype=VOICE
        CCB:callid=80AC, sapi=0, ces=0, B-chan=19, calltype=VOICE
        CCB:callid=80BA, sapi=0, ces=0, B-chan=21, calltype=VOICE
        CCB:callid=80C5, sapi=0, ces=0, B-chan=22, calltype=VOICE
        CCB:callid=80CE, sapi=0, ces=0, B-chan=18, calltype=VOICE
        CCB:callid=80E7, sapi=0, ces=0, B-chan=17, calltype=VOICE
        CCB:callid=80FF, sapi=0, ces=0, B-chan=16, calltype=VOICE
    Active dsl 0 CCBs = 8
    The Free Channel Mask:  0x80007FFF
    Number of L2 Discards = 0, L2 Session ID = 2
for the active serial interface but when I do show voice call status I get:
CallID     CID  ccVdb      Port        Slot/DSP:Ch  Called #   Codec    Dial-peers
No active calls found
There are 3 users on tty ports, two show:
dsx1(slot/unit/channel)=NONE, status=VDEV_STATUS_UNLOCKED
for the show line command but one shows:
I want to clear the channels that aren't actually in use but not ones that are.  These are not actually voice calls but calls to modems that I think sometimes don't get the ath command sent.
Hi.
Do you have configured TTY on your Voice gateway?
If yes please post your config here.
And if show voice call status doesn't give any output while show isdn status or show isdn active give some output, probably they are all TTY sessions.
Let us know
Carlo
Please rate all helpful posts "The more you help the more you learn"
Not sure what you mean "Do you have configured TTY on your Voice gateway?".
I am using DDR dialer profiles:
interface Serial3/0:23
 no ip address
 encapsulation ppp
 dialer pool-member 1
 isdn switch-type primary-dms100
 isdn incoming-voice modem
 isdn map address *.* plan isdn type national
 isdn outgoing display-ie
 no cdp enable
interface Dialer1
 no ip address
 encapsulation ppp
 dialer pool 1
 dialer idle-timeout 3600
 dialer-group 1
 no cdp enable
 ppp authentication chap
 ppp multilink
interface Group-Async0
 ip unnumbered GigabitEthernet0/0
 encapsulation ppp
 no ip mroute-cache
 dialer in-band
 dialer-group 1
 async dynamic address
 async mode interactive
 peer default ip address pool dyn_pool
 compress mppc
 ppp pfc remote ignore
 ppp acfc remote ignore
 ppp callback accept
 ppp multilink
 group-range 1/00 1/59
 routing dynamic
line 1/00 1/59
 session-timeout 60
 exec-timeout 15 0
 script modem-off-hook offhook
 script callback callback
 no modem InOut
 rotary 1 queued
 no exec
 transport preferred none
 transport input ssh
 transport output telnet
 escape-character NONE
 autoselect during-login
 autoselect ppp
 autohangup
What I meant is if you are using your T1 for data calls.
Can you please share a show isdn active detail and a show line?
Carlo
Yes I am using the circuit for data calls.  It is an ISDN PRI - T1
as5350xm#show isdn active
                                ISDN ACTIVE CALLS
Call    Calling      Called       Remote  Seconds Seconds Seconds Charges
Type    Number       Number       Name    Used    Left    Idle    Units/Currency
Out   ---N/A--- +1234567890                     3 Unavail   -          0
as5350xm#sh isdn status
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
    Layer 3 Status:
        10 Active Layer 3 Call(s)
        CCB:callid=8116, sapi=0, ces=0, B-chan=15, calltype=VOICE
        CCB:callid=8134, sapi=0, ces=0, B-chan=17, calltype=VOICE
        CCB:callid=8135, sapi=0, ces=0, B-chan=16, calltype=VOICE
        CCB:callid=8136, sapi=0, ces=0, B-chan=14, calltype=VOICE
    Active dsl 0 CCBs = 10
    The Free Channel Mask:  0x80001FFF
as5350xm#who
    Line       User       Host(s)              Idle       Location
*  2 vty 0     xxxxxxxx        idle                 00:00:00 172.16.3.2
  tty 1/06     yyyyyyyy        incoming             00:03:45 172.16.3.2
  tty 1/07     zzzzzzz        incoming             00:00:00 172.16.3.2
  tty 1/09     aaaaaaa        incoming             00:00:01 172.16.3.2
  Interface    User               Mode         Idle     Peer Address
as5350xm#sh line 1/06
   Tty Typ     Tx/Rx    A Modem  Roty AccO AccI   Uses   Noise  Overruns   Int
*     1/06 Digital modem -    -      1    -    -     84       2     0/0       -
Line 1/06, Location: "", Type: "xterm"
Length: 65 lines, Width: 237 columns
Status: Ready, Connected, Active, Notify Process
Capabilities: EXEC Suppressed, Hardware Flowcontrol In,
  Hardware Flowcontrol Out, Line usable as async interface,
  Hangup on Last Close, Integrated Modem, Async Queueing
Modem state: Ready
  modem(slot/port)=1/6, state=CONNECTED
  dsx1(slot/unit/channel)=3/0/16, status=VDEV_STATUS_ACTIVE_CALL.VDEV_STATUS_NEGOTIATED.
Modem hardware state: DTR  DCD*  CTS  RTS*
Group codes:    0
Special Chars: Escape  Hold  Stop  Start  Disconnect  Activation
                none   none   -     -       none
Timeouts:      Idle EXEC    Idle Session   Modem Answer  Session   Dispatch
               00:15:00       01:00:00                       none     not set
                            Idle Session Disconnect Warning
                              never
                            Login-sequence User Response
                             00:00:30
                            Autoselect Initial Wait
                              not set
Modem type is unknown.
Session limit is not set.
Time since activation: 01:07:37
Editing is enabled.
History is enabled, history size is 20.
DNS resolution in show commands is enabled
Full user help is disabled
Allowed input transports are ssh.
Allowed output transports are telnet.
Preferred transport is none.
No output characters are padded
No special data dispatching characters
as5350xm#sh line 1/07
*     1/07 Digital modem -    -      1    -    -     38       3     0/0       -
Line 1/07, Location: "", Type: "ibm3151"
Length: 25 lines, Width: 80 columns
Modem state: Ready
  modem(slot/port)=1/7, state=CONNECTED
Group codes:    0
                none   none   -     -       none
                              never
                             00:00:30
                              not set
Time since activation: 01:46:18
Editing is enabled.
as5350xm#sh line 1/09
*     1/09 Digital modem -    -      1    -    -     26       1     0/0       -
Line 1/09, Location: "", Type: "vt100"
Length: 36 lines, Width: 120 columns
Modem state: Ready
  modem(slot/port)=1/9, state=CONNECTED
  dsx1(slot/unit/channel)=3/0/13, status=VDEV_STATUS_ACTIVE_CALL.VDEV_STATUS_NEGOTIATED.
Group codes:    0
                none   none   -     -       none
                              never
                             00:00:30
                              not set
Time since activation: 00:02:20
Editing is enabled.
