Showing results forĀ
Search instead forĀ
Did you mean:Ā
How find which E1 number belong to which Voice Gateway ?
SubnetWarrior
Hai experts!
So my company has hundreds E1's number in its CUCM. I want to find out which E1 number belong to which VG. We have 2 voice gateways.
I have check E1 0/0/0 in VG01 and E1 0/0/0 in VG02. Both E1 0/0/0 in each VG has same  description which is written that the initial E1's number is 5237XXX.
Any enlighment?
Jaime Valencia
Aside from running debugs, this is a conversation you need to have with your telco, they're the ones that handle incoming calls.
java
if this helps, please rate
