How i can configure and use wireless head set on cisco 7962...?
midhun_km
Hi all,
is it possible...?
Thanks in advance...
Midhun KM
Rob Huffman
Hi Midhun,
To be able to answer/end calls via the Plantronics wireless headset
you require this additional part
See attached
Cheers!
Rob
Plantronics 37978-01 Plantronics Cisco Headset Hookswitch Control Adapter (HHC)
  • Cisco Headset Hookswitch Control (HHC) adapter transforms your Cisco Unified IP phone experience by extending the advantages of Plantronics professional wireless headset system families
  • Supports Plantronics CS50, CS55, CS70N, CS351N, CS361N wireless headset systems, and Plantronics Voyager 510S Bluetooth headset system
  • Enables remote ring alert and call answer/end capability on your Plantronics wireless headset, allowing you to move freely throughout the office without missing a call
  • Eliminates the need for Plantronics HL10 handset lifter
  • Once connected, the HHC will send a ringer alert signal to the headset anytime the phone rings, anywhere within a headset's wireless range
Plantronics Cisco Headset Hookswitch Control Adapter (HHC).
Compatible with Cisco Unified IP Phone models 7975G, 7965G, 7945G, 7962G, and 7942G.
This product is also known as: Cisco Hookswitch, Cisco Control Adapter, Cisco HHC, APC-4
On the Device configuration page in CUCM for the 7962 where you want to use the Wireless headset (enable the setting below);
Product Specific Configuration Layout
midhun_km
http://www.voiplink.com/Cisco_7960_Headsets_s/362.htm
This link shows it is possible....
how i can configure the same..?
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/firmware/8_3_5/english/release/notes/79x5x2_835.html
from the above shown link from Cisco documentation....
Enabling a Wireless Headset
By default, the wireless headset remote hookswitch control feature is disabled. You can enable it through
the Cisco Unified Communications Manager Administration application. To do so, choose Device >
Phone and locate the phone you want to modify. In the Phone Configuration window for the phone,
select Enable for the Headset Hookswitch Control option.
On the phone, you can verify that the feature is enabled by choosing Settings > Device Configuration
> Media Configuration, and verifying that the Headset Hookswitch Control setting displays Enabled.
Rob Huffman
Hi Midhun,
See attached
Cheers!
Rob
Hi..Rob...
Excellent.......
Good Day_ Bro....
