How much PoE Power does a 8961 Actually use ?
Fraser Reid
Hi All
I would like to know the actual power requirement for a 8961 when used with a 3750x Switch
I have seen only 15.4 W in every document I have found but that just goes by the fact that the phones are class 3.
A 7962 is class 2 but uses only 6.2W instead of the 7.5 that could be possible.
Can someone answer this that actually has this model in use ?
Cheers
Fraser
phooghen
Cisco Ip phone 8961
802.3AF Classification  / Maximum Watts :Class 4(15.40W)
CDP (W) for Budgeting PoE :9.6
Actual Power when Idle (W)* :6.1
Power Save mode*:5.1
Power Save Plus mode: 1 Watt
Pierre.
phooghen
Cisco Ip phone 8961
Pierre.
Hello Pierre.
Is there a PDF where this information is contained ? Also for other Telephones (the 9000 Series) ?
Fraser
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/9971_9951_8961/7_1_3/english/admin/guide/9971apxd.html
Power
100-240 VAC, 50-60 Hz, 0.5 A—when using the AC adapter
48 VDC, 0.2 A—when using the in-line power over the network cable
As far as I remember to get Watts you need:  48VDC * 0.2A = 9.6 W
HTH, Volodymyr
Fraser Reid
check this out too guys.....
from CDP on a 3750X Switch for a 8961 IP Phone......
Device ID: SEPE840400CF086
Entry address(es):
  IP address: 10.146.160.26
Platform: Cisco IP Phone 8961,  Capabilities: Host Phone Two-port Mac Relay
Interface: GigabitEthernet2/0/38,  Port ID (outgoing port): Port 1
Holdtime : 141 sec
Second Port Status: Down
Version :
sip8961.9-1-1SR1
advertisement version: 2
Duplex: full
Power drawn: 8.973 Watts
Power request id: 34545, Power management id: 3
Power request levels are:8973 0 0 0 0
Management address(es):
and now on the same switch.......
Device ID: SEPE84040A2549D
Entry address(es):
  IP address: 10.146.161.196
Interface: GigabitEthernet1/0/26,  Port ID (outgoing port): Port 1
Holdtime : 135 sec
Second Port Status: Up
Version :
sip8961.9-2-1
Duplex: full
Power drawn: 9.503 Watts
Power request id: 40277, Power management id: 3
Power request levels are:9503 0 0 0 0
strange......
ios all identical.....
