How to add an 8861 to CUCM 9.1.2
sparklemotion
The release notes for the phones indicate that 8861 is supported by  CUCM 9.1.2 however I can not figure out how to add it.  I don't see any DevPack that would allow me to add the phone, only the COP file.  Anyone have a link to the devpack i would need to install.. or am I suppose to add the phone as a third-party-sip?
Jaime Valencia
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/compat/matrix/CMDP_BK_CCBDA741_00_cucm-device-package-compatibility-matrix.pdf
java
if this helps, please rate
you can download the Device pack 9.1(2.13070) from below link and upload in server.Restart the server.
https://software.cisco.com/download/release.html?i=!y&release=9.1(2.13070)&mdfid=284510097&softwareid=282074299&os=
regds,
aman
Brandon Pierce
Level 4
Level 4
The 9 and 10 device packs are within the SIP loads....Not sure what you are looking for.  I had to pull 8831 cmterm files today.
Andrew West
Level 4
Level 4
Just need to load the DevPack that supports those phones along with anything else you need like the DX80, 90s or other.
Jamie listed the matrix below that will give you the list.
