how to block outgoing call to specific Numbers in cucm 10.5
eng333m
George Sotiropoulos
On your CUCM Admin Page, you will go to "Call Routing"->Route/Hunt->Route Pattern.
You will create a new Route Pattern with the number you want to block (on the correct Partition) and then on the Route Option  you will need to Select "Block this Pattern".
George
Hope the above helps,
gsotirop
George Sotiropoulos
Did the above work for you?
gsotirop
