08-03-2014 10:54 PM - edited 03-16-2019 11:37 PM
I have a Cisco IP 7961 with a 7914 Expansion Module and I need to change the staff speed dial names. I've printed off the manual but I can't figure it out?
08-13-2014 05:22 AM
is it on CUCM ?
regards
Chintan
08-13-2014 12:32 PM
Please check out the following link if you are using a CUCM
https://supportforums.cisco.com/document/12098351/configuring-speed-dial-and-abbreviated-dial-setup-cucm
08-19-2014 09:11 AM
HI,
Are you trying to change the speed dial in CUM or in Phone.
If you are are trying to change in Phone,then manually change in the phone.
If you are trying to change in CUCM follow the link provided by Pedro
Gurudath K S
