03-26-2012 02:44 AM - edited 03-16-2019 10:17 AM
Cisco IP Phones 7911 and 7940 have correctly updated time-zone, but cisco type 7942 does not want to update timezone.
How to check time on remote cisco IP phone 7942?
03-26-2012 02:48 AM
HI
Just give ip address of the phone in internet browser. It will open IP phones information window. It has following information
Time | 15:17:34 | |
Time Zone | Asia/Kolkata | |
Date | 26/03/12 |
Ronak Patel
Please rate helpful posts.
03-26-2012 03:01 AM
I forgot to say, ip address of the phone in internet browser shows info only for 7911 and 7940, for 7942 does not show anything.
03-26-2012 03:04 AM
What is the CUCM and Firmware on that phone.
Ronak Patel
03-26-2012 03:18 AM
Cisco Unified Communications Manager Express
Version 7.1
load 7942 SCCP42.8-3-3S
03-26-2012 03:04 AM
What is the firmware version running on 7942 ? Update it to the latest if not already.
GP.
03-26-2012 03:47 AM
It is installed:
Version 7.1
What from bellow should I use for a new firmware:
1. apps42.9-2-3TH1-9.sbn
2. cnu42.9-2-3TH1-9.sbn
3. cvm42sccp.9-2-3TH1-9.sbn
4. dsp42.9-2-3TH1-9.sbn
5. jar42sccp.9-2-3TH1-9.sbn
6. SCCP42.9-2-3S.loads
7. term42.default.loads
8. term62.default.loads
03-26-2012 03:50 AM
It will be SCCP42.9-2-3S.loads but am not sure if direct upgrade will be possible looking at present & targetted versions. If it doesnt then an intermediate upgrade step will be needed. Referring the release notes for firmware version 9.2.3 should tell you if it needs one & what it is.
GP.
03-26-2012 04:07 AM
Is phone and CME router on same network or are seperate via some VPN.
Also please do no create cnf-files and create cnf-files and reset the phones
Ronak Patel
03-26-2012 04:13 AM
phone and cme are on the same network.
no create cnf-files, create cnf-files and phones reset did not help.
