How to configure CME on 4321 ISR router
@Syed
Level 3
Level 3
Hi All,
I have a brand new cisco 4321 & 4351 ISR router.
May I have a document for CME configuration on 4321&4351, please.
It should something like below if the DSP is on NIM when you would run the command show inventory
NAME: "subslot 0/1 db module 0", DESCR: "PVDM4-128 Voice DSP Module"
PID: PVDM4-128 , VID: V01, SN: FOC17176BLL
It is like a card that you need to take out and put it in.
Abhay
Abhay Singh Reyal
The Only Way To Do Great Work Is To Love What You Do. If You Haven’t Found It Yet, Keep Looking. Don’t Settle
5 Replies 5
Find the below links helpful
https://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-express/211270-Basic-Configuration-Guide-for-CUCME-CME.html
http://www.ciscopress.com/articles/article.asp?p=1182471&seqNum=2
Note :- In order to configure the PRI on ISRG4, kindly be advised to move the PVDM from Mother Board to the Network Interface Module [In case there it is not there on NIM]. Most of the times you would get an error while configuring the PRI and then you need to take the step.
You can verify the settings by running command show inventory
Abhay
Kindly rate all helpful posts !!!
Abhay Singh Reyal
Hi Abhay,
Thank you very much for the document, but it is not very clear. It would helpful if you could share a clear one, please.
Have you already reviewed the CME configuration guide??
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/manual/cmeadm.html
java
if this helps, please rate
Hi Abhay/Jaime,
How do I make out whether PVDM4 is on motherboard or NIM from the attached bill of quantity. I know that we can find by show inventory. Is there a way to make sure without powering the router on??
If it is on motherboard then how do I change it to NIM??
Thank you in advance
Syed
Abhay
Abhay Singh Reyal
