how to configure qos in cisco 2960 switch
ankur
hi
i want to know that how to configure qos in cisco 2960 switch.
dijohn
Here's a doc which explains the same
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_25_see/configuration/guide/swqos.html#wp1231434
You could go the auto qos way too
/divin
PS: Rate useful posts!
Leo Laohoo
I want to know which SPECIFIC MODEL do you have.  Some 2960 do not support QoS.
As pointed out above, some 2960 do not support qos.  However, the ones that do have the following characteristics:-
Queues
Global ingress queues = 2 with 2 configurable threshold values per queue and one system set.
Per port egress queues = 4 with 2 configurable threshold values per queue and one system set
Basic overview of setting up QoS using MQC (Modular QoS using CLI)
1. Traffic Classification using ACL
Specify what traffic you want to mark
2. Traffic match using class-map
Configure class-map match-any/all 'name'
match 'ACL'
3. Traffic marking using policy map
Configure policy-map 'name'
Specify the class-map 'name'
set ip dscp 'marking' dscp value
4. interface #/#
service-policy input 'policy-map name'
In regards to markings, I tend to use layer 3 DSCP markings as thats still preserved over hops.
I suggest you looking to qos mappings to understand more on how it works.  A couple of useful commands:-
show mls qos maps
show mls qos interface statistics (showing if packets are getting marked etc)
Hope that helps.
Mo
