03-07-2013 02:51 AM - edited 03-16-2019 04:07 PM
I have a problem with configuring the CUCME 8.6 (Cisco 2911/K9) with the SPA303 IP phone.
In our company, we have several IP phones (CP-6921), which are configured and registered via SCCP and everything work perfectly. However, we have several other IP phones (SPA303), which don't support SCCP. So instead, I need to configure them as SIP phones. I am new to this, so I have searched and found this document:
So I have configured CUCME and the SPA303 phone according to this document, but the line on the phone is signaling, that the registration has failed. Here is part of the running config from CUCME:
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
no supplementary-service sip handle-replaces
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
bind control source-interface GigabitEthernet0/1
bind media source-interface GigabitEthernet0/1
registrar server expires max 600 min 60
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
voice register global
mode cme
source-address 192.168.20.1 port 5060
max-dn 100
max-pool 50
tftp-path flash:
create profile sync 0048234055148343
voice register dn 8
number 21
name Spravce
shared-line
huntstop
label Kancelare
voice register pool 1
id mac 3CCE.73D2.BF6A
number 1 dn 8
dtmf-relay sip-notify
username user21 password user21
codec g711ulaw
I am very grateful for any help
Message was edited by: Lukas Krejci There is might be another problem - I was not able to load the flash for SPA303 in CUCME. I donwloaded the right file and when trying to upload and configure it through the wizard in Cisco CP, there was always an error about the unknown type of phone.
03-07-2013 04:53 AM
Try this:
Configuring CUCME.
All in all this is a painless process. First, configure the voice services:
voice service voip
allow-connections sip to sip !Allows SIP phones to call other SIP phones
sip
registrar server expires max 1200 min 300 !Enable IOS SIP Registrar
Next, we will configure the voice register configuration stanza. The "voice register global" configuration is similar to the telephony-service configurations used for SCCP phones.
mode cme
source-address 10.3.5.2 port 5060
max-dn 10 !Configure the maximum number of SIP extensions
max-pool 5 !Configure the maximum number of SIP phones
authenticate register
authenticate realm netcraftsmen.net !Doesn't impact X-Lite whether it is applied or not
tftp-path flash: !Not necessary to get X-Lite to register, but useful for Cisco SIP phones
create profile !Generates configuration files for phones
Now we create the directory number for the X-Lite station and the phone registration information.
voice register dn 1
number 51234
allow watch !If you are doing any Presence-like things
name xlitetest
label 51234
id mac DEAD.BEEF.0001 !Just as with CUCM, this field is arbitrary and not used by X-Lite
number 1 dn 1 ! Of course you need a phone number to use a phone, but X-Lite also needs a user ID
dtmf-relay sip-notify ! You have choices here, use sip-notify if you also have CUE for VM
username bbellsip password t3st1ngxl1t3 !Required for X-Lite
codec g711ulaw ! Or whatever you need. NOTE: X-Lite basic (free) only supports G711
Please rate all useful posts
Favor calificar todos las respuestas útiles.
___________________________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
MDGDP, CCNA, CCNA Voice, CCNP Voice Certified
03-07-2013 05:13 AM
Thank you for fast reply, but I have read this and as you can see from my configuration listing, I have configured everything mentioned in the article.
03-07-2013 05:36 AM
I have another question, that might be connected with this problem: Is there a firmware for this phone, that our CUCME (C2911/K9) might succesfully load?
03-07-2013 09:03 AM
No, there is not need to any firmware here because is working a Standard SIP Client it should work..
Did you tried to connect using X-lite or another SIP Client?
04-22-2013 05:52 AM
I have managed to get this phone to register, so now I can call it from other
(SCCP) phones in the company and vice verca. But I still cant make outgoing calls on this phones, while on the other (SCCP) phones, this works fine.
04-22-2013 06:53 AM
Did you try running a SIP Softphone client?
Please remember to rate useful posts clicking on the stars below.
04-23-2013 01:00 AM
Yes, I have tried X-lite and it works the same as the phone - registration is ok, calling between phones in company is ok, but outbound or incoming calls are failing to establish (the spa303 displays Service Unavailable, and X-lite displays: Failed to establish call).
