09-29-2009 10:16 PM - edited 03-18-2019 10:39 AM
Dear Collegue,
Existing VG224 Analog gateway is working fine connected to fax machines running h323 protocol. We want to activate the Force Authorization Code to conrol the facilities and this will work only in MGCP Protocol.
Your output and quick solution is highly appreciated.
Thank you
09-29-2009 10:46 PM
09-30-2009 07:13 AM
Dear Virender,
The doc is okay. Do you have anything specific for the configuration of Fax Machines using the VG224 using MGCP Protocol to run the Force Authorization Code.
Your quick reply is highly appreciated.
Thank you
09-30-2009 10:12 AM
ok,
fax search matrix,
vg224 will support pass-through and relay,
http://www.cisco.com/en/US/partner/tech/tk652/tk777/technologies_tech_note09186a0080159cf3.shtml
search for mgcp fax pass-through in following....
10-01-2009 12:06 AM
Hi Virender,
Thanks a lot. I will try to apply the sample config and see.
I will drop an e-mail if I need more help.
10-01-2009 04:42 AM
This is actually not true.
MGCP supports:
NSE based T38
Protocol based T38
NSE modem passthrough
modem relay
cisco fax relay
H323 supports:
NSE T38
Protocol based T38
protocol based pass-through
modem relay
cisco fax relay
The difference here is NSE is 'passthrough' and protocol based is pass-through.
If you're using a SIP provider for instance, and they're doing passthrough, you won't be able to use MGCP in the call flow.
-nick
10-02-2009 09:26 PM
Hi Nick,
Thank you for your feedback. Do you have any sample config that will help to establish the fax machine that was connected to VG224 Analog Gateway using MGCP protocol. The reason why they want to use MGCP is to use the Force Authorization Code for Fax Devices.
Any comments and suggestion is appreciated.
10-05-2009 05:30 AM
This depends entirely on which of the above options you want to use. There are about 4 different ways.
-nick
09-30-2009 01:33 AM
I think it is related to CSS applied to the phone, so you can try it using sccp for the VG224 so as to not missing the great fetaures of it
thanks
