How to customized GUI of Unity Connection CiscoPCA or CUCM ccmuser?
sky_voice
Has anyone customized GUI portal of Unity Connection Cisco PCA or CUCM ccmuser GUI ?
We have certain requirement where we want to disable specific functions for end users.
Thanks..
Jaime Valencia
CCMuser you can configure what is available under enteprise parameters.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Thanks Jamie!
Actually I am keen to  see customization on Unity Connections web inbox. Looks like it is as standards as we see.
I thought somewhere should be an option, like we customize phone menu's.
Cheers,
