Hi all,
On a partiular 2821 Cisco ISR which is equipped with multiple C5510s which are configured for transcoding, we have a recurring problem with distored voice or choppy voice when calls are transcoded from G711 to G729.
I can see from the IOS that there is a global test command (not hidden) that enables testing of the DSPs. However, it is not evident how this command should be used, for example:
#test dsp ?
debugger Test DSP global debugger
device Test DSP device
memory Test DSP memory
recovery Test the DSP auto-recovery
#test dsp device ?
<0-2> Slot id - the module id on the system.
all all slots to be acted upon
print print DSPs not in "show voice dsp"
<cr>
#test dsp device 0 all ?
dspware Download flash file system DSPware.
remove Remove the specified DSP(s).
reset Reset the specified DSP(s).
restore Restore the specified DSP(s).
Has anyone used these commands before to test for a faulty DSP?
