02-21-2012 06:47 AM - edited 03-16-2019 09:41 AM
Could someone be kind enough to tell me how to disable intercom once it has been set up please? Any help would be greatly appreciated as a client requires it disabled.
Am using CUE V7 if that is any help?
Solved! Go to Solution.
02-21-2012 06:04 PM
Chris, there is nothing in the config naming intercom. The only phones that have that sort of number sequence for button are named individuals. And there is no barge-in command used at all.There is a couple of paging commands in there though.
Rob
02-22-2012 06:23 AM
Well, that means you do not have any intercoms setup, so there is nothing to disable. Perhaps you misunderstood the feature they are using. What needs to be removed? Either way the way you remove it is identify which button it is on which ephone and then issue:
ephone 5
no button X:Y
where X is button location (i.e. 2 for second button on the phone) and Y is the ephone-dn you need to remove.
Chris
02-22-2012 08:44 AM
Thanks for your help Chris. All is understood. Have a gday..
