HOW TO DISABLE SPEAKER FOR 6921 / 7945 IP PHONE IN CUCM
nabeel asghar
Hi Experts,
Greetings,
I want to disable speaker button of my IP Phone i.e if a user is having any incoming call, he must not be able to answer it through speaker but can only be able to answer by lifting handset.
we are having CUCM 8.6
Please advice on the same
Warm Regards:
Nabeel
No problem.
please rate all useful posts!
5 Replies 5
Chris Deren
Check "Disable Speakerphone" on the device page, if you need to do this for many phones you can use BAT.
Thanks Chris :)
No problem.
Can you help me for below
https://supportforums.cisco.com/discussion/12678376/no-beep-notification-after-no-answer-pstn-call-system-recording-only
Warm Regards:
Nabeel Asghar
Dear Chris
Please help me out for the below post urgently
Regards:
Nabeel Asghar
