12-28-2014 10:33 PM - edited 03-18-2019 11:27 AM
Hi all
I have an end user with two different DN, CUCM is integrated with active directory using LDAP. As per the company policy can’t create two accounts . So how to display all the phone associated with the user in the corporate directory .?
Please help
12-28-2014 10:46 PM
You would need to write down your own directory script in order to do that
12-29-2014 06:45 AM
Can i do something on cucm instead of altering the ldap ?
12-29-2014 07:31 AM
What is your version of CUCM? As of 9.X you can build local users when you are LDAP integrated, so if you are on 9.X+ you could build second user with desired number for the user.
12-29-2014 10:25 AM
Notice I NEVER mentioned anything about altering the LDAP, I said you had to write down a directory script to do that.
01-13-2015 01:01 PM
I am having the same issue and the only reference I could find to LDAP directory scripting referenced an SDK and required a dedicated IIS server. Is that the solution you are referring to?
BTW: I am running BE6000/ Call Manager 10.5.
