How to Download VMware Esxi trial version 7
naeemu518
download the VMware ESXI version 7 which is running on UCS server C240 BE7k for used for trial. Give me also instruction about installing the VMware ESXI on UCS server BE7k which thing is required for installation.
b.winter
The VMware will be delivered already with a 60 or 90 day evaluation license
It’s still unclear what exactly you’re trying to achieve. The VMware that comes pre-installed on the BE7K can be downloaded from the data store. You can use them in evaluation mode, although I don’t recall the duration - it’s either 60 or 90 days. Once the evaluation period expires, you’ll need to reinstall it. However, if you’d like to continue using it without reinstalling, then you’ll need to obtain a license key.
To install VMware on the UCS 240 server, you’ll need to boot the VMware ISO image using the UCS CIMC KVM console. Mount the ISO and boot it from the CIMC.
Response Signature
