How to eject the DVD from CUC
Jagsuvce G
I need to reboot the CUC server in which i have just upgraded the Patch through SFTP. Before that i had inserted the Bootable DVD (Patch 8.6.2). Its still connected to the server, now i need to remove/eject the DVD from the DVD Drive which is connected to Server.
Any command to eject the dvd ?? I referred all Cisco guides, it says do it physically but the
Pls suggest.
Jaime Valencia
There's no command to eject the disk tray, you need to go to the server, and press the eject button
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jaime Valencia
java
java
Nagabhushana .g
If you have ILO(Integrated Lights-Out) access to this server ..then change the booting sequence order CD/DVD to HDD from BIOS setting. So after server restart, server will bootup with CUC OS.
Bhushan
Chris Deren
What is the server manufacturer?
Chris
Unlucky, i dont have ILO configured and Server model is MCS 7825 H2 .... HP Server.
