How to find active calls (LAN & WAN) in CUCM
Syed
Level 3
Level 3
Dear All,
How do I know the number of active/live calls (LAN & WAN) in cucm.
Thank you
2 Accepted Solutions
Gordon Ross
Level 9
Level 9
The best you can do, is use RTMT to see the total number of calls on a device (Subscriber, gateway, MTP, etc). But you can't break down active calls any other way, or even get a list of the calls.
GTG
Please rate all helpful posts.
anshumansingh45
you can check the active calls on your IOS router either through the ISDN channels which are reserved or through the dial peers in use at that particular frame of time. But using RTMT would be a best idea.
show voice call status
show isdn active
show call active voice
show call active voice br
show call active voice (on mgcp)
show voice call summary
show dial-peer voice summary
sh voice port summary
Also if you want to see the active calls with ANI and DNIS info, then above can be useful. you can find many more if you type ? after show voice..
Anshuman Singh
+971 555012936
Gordon Ross
Level 9
Level 9
GTG
Thank you Gordon,
This helped...
anshumansingh45
show isdn active
Anshuman Singh
+971 555012936
Thank you Anshuman,
I have also got a couple of FXOs and FXSs, it would be helpful if you could suggest some basic troubleshooting commands and their impact on router CPU?
