How to find Concurrent IPIVR Ports in UCCE
yogesh shah
Beginner
Beginner
How to find Concurrent IPIVR Ports in UCCE 11.5
Glad that it worked Yogesh, please remember to mark the thread as ANSWERED if there are no further questions on the topic.
Deepak
8 Replies 8
Deepak Rawat
There is no way to find it in real time however you can run License Utilization Hourly Report from CUIC that will tell about the maximum number of inbound ports used for the given date and hour.
Deepak
Thanks for response.
Please can you provide the sql query for this report shows IPIVR ports. I have for UCCE license.
I need ONLY for IPIVR
{call sp_license_utilization('2017-08-03 18:30:00','2017-08-04 18:29:59','0','1')}
If you run for IPIVR CLI then use it below:
run uccx sp db_cra sp_license_utilization('2017-08-03 18:30:00','2017-08-04 18:29:59','0','1')
Time in the query is converted to GMT so do the offset accordingly i.e., while running report I choose the time as 12:00:00 AM - 11:59:59 PM and as my server is in IST Time Zone hence the time in GMT was offset to -5.30 hrs both in Start and End interval
Deepak
(Remember to Rate Helpful Posts)
Hi Deepak,
Need more help. Everything good, where do i find my DB name ? like your db_cra ?
Let me know.
Thanks again for the help
run uccx db_cra sp_license_utiliztion('2017-08-03 18:30:00','2017-08-04 13:29:59','0','1')
No valid command
incomplete command ?
i found db name is still same name.
I found my typo.....
thanks very much it works now.
Awesome.
Deepak
You are missing sp in front of db_cra and also the spelling of utilization is not correct. Check the command I shared earlier carefully and simply change the date and time as per your requirments.
Deepak
Recognize Your Peers
