how to find the ip of the unity
ben Zecharia
hello ,
I am connected to cucm 8.0.3
there is unity  in the cluster but I dont know what  his ip .
how can I find out ?
mkchandak
On CUCM, go to Voicemail port and there you would see 2 IPs. 1 is the IP Of the CUCM to which the ports are registered and the other one would be the IP Address of your Unity.
Hope this helps.
mkchandak
Hope this helps.
This idea assum that you are using SCCP integration where your voicemail ports register with CUCM. If you are using sip integration you are not going to see any ip address..You will need to go to the sip trunk and look at the destination address to get the ip address of your unity/unity connection server
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
