available and used?This is version 7.1.5Thanks!Tracee
Hi I have created SIP SRST on Voice Gateway, How can I check whether SRST is working fine without disconnecting WAN ?Also i went through some post and foun that need to enter "mode SRST" command under voice register global, but in my case i can't fin...
Correction, I mean 2901 not the 2921. Will 2901 be able to be both a voice gateway for PSTN and normall router for data? hey, thereI have a remote site deployment coming up and we bought a 2921 router as voice gateway for the 24 local phon...
Hi Guys,In the last 19 October, in any city of Brazil started of date summer time (DST), and the IP Phone models 7940/7960 not changed the time automatically. After restart physical or logical the IP Phone stay the correct time. 7940Firmware de aplic...
Hi Allour one client company alrady running Avaya ip office 500v2 .this company want to call center solution iam prifer to cisco contact center solution.one question possible to integration to avaya to cissco contact center ? please update fast.Than...
Hi I have cucm 9.1.1, with 6921. user ccomplains that they can't hear voice time to time, call is ringing but their MIC is not working. after repluging the phone to network this is resolve. what will be the cause for this ? how can we troubleshoot th...
Hi,As per the vulnerability report (Qualys Guard), we are seeing couple of vulnerabilities wrt 7940 IP Phones.The report says...OS: Linux 2.4-2.6 / Embedded Device / F5 Networks Big-IPIssue:Web Server/ Web Application Vulnerable to Cross-Site Scripti...
Hi all,need help to configure IVR for internal number for press 1 sales and 2 for HR ..........i have cucm 8.5 and CUBE voicegatway with sip trunks from pstn and to cucm i don't have connection, cue, uccx.want to implement in CUBE Do any body have t...
Hey,I'm trying to understand the complications of using the incoming calling party settings with ISDN TON National and Subscriber. I went through the Cisco Live Adanced Dial Plan presentation and looked many other places but have ended up confused. T...
When i am doing call from GW e using isdn test call interface se0/0/0:15) outgoing work fine But end user are not able to make outgoing although they are able to receive calls.
Dear All,We try to integrate Avaya to Call manager using SIP Trunk.for now, avaya ip phone can call to cisco ip phone, but cisco ip phone can not call to avaya ip phone.when i collect rtmt debug, it saidSIP/2.0 403 Forbidden(Invalid domain in From: h...
Hi,I have registered several IPPhones 6921 in cucm via wan, and trying to make a pickup Group, when I place a call, runs the hunt group, but when i try to pick up the call with Pickup Group softkey in the ipphones shows the message "temporal error" a...
Hi AllI have the follow problem: Local Agent is not responding. This may be due to Master or Local Agent being down1.- I performed a restart of the Master and Local Agent Services2.- I performed a restart of the Tomcat Service.3.- In the Publisher, t...
Hello ExpertsI cannot delete existing license file which have wrong license of my cucm , is there any idea?.Thanks
Hello,We are currently running an older router which works fine for our needs, as specified in the topic. I am trying to access the GUI for the AIM-CUE and am unable to. I can access the /ccme.html for the router, but that is not integrated with the ...
Subject | Author | Posted |
06-17-2025 07:43 AM | ||
06-17-2025 06:11 AM | ||
06-09-2025 09:11 AM | ||
06-05-2025 02:29 PM | ||
05-29-2025 01:49 AM |
User | Count |
3 | |
2 | |
1 | |
1 | |
1 |
