05-04-2017 06:01 AM - edited 03-17-2019 10:14 AM
i have a customer who wants to forward a call after three rings to another number , what sort of commands i need to do that in CME CLI? for example a user is
ephone-dn XX octo-line
number XXXX
label XXXX
Solved! Go to Solution.
05-04-2017 06:12 AM
You can do the following:
Voice(config-ephone-dn)# call-forward noan XXXX timeout 12
Where XXXX is the extension that you want to forward to
Manish
05-04-2017 06:12 AM
Manish
05-06-2017 09:54 PM
thank you for the great input and what about if i want the phone to forward to a number if his line is busy?
05-07-2017 10:02 PM
call-forward busy XXXX
where XXXX is the extension to which you want to transfer when the extension is busy.
Manish
05-07-2017 10:49 PM
ephone-dn
call-forward busy xxxx
