How to forward a call directly to someone's voice mail
mmedwid
Level 3
Level 3
Imagine an admin with 6 exec line appearances on her phone.  Caller calls Exec A and the admin answer.
She normally take a message but in this case the caller specifically wants to go to Exec A's voice mail.
Is there a way to do that?  Am I missing something obvious?
Marwan ALshawi
Add a CTI RP with *XXXX and CallFwdALL to Voicemail
But make sure your default voicemail profile has mailbox mask XXXX listed or this won't work
so if the Exec A number it 1000 yu can dial *1000 then the call wil go to VM of number 1000 assuming the mail box mask created with XXXX so the * get removed
if helpful Rate
Marwan ALshawi
if helpful Rate
Bingo!  All good.  Thank you.
