how to generate XMLDefault.cnf.xml on tftp
sarahr202
Level 5
Level 5
Hi everybody.
No ip phone is connected.  I am trying to see how XMLDefault.cnf  file can be created and transfered to tftp server
Tftp server------sw--------cme router
tftp--201.201.201.3
cme 201.201.201.1
The Tftp server should have XMLDefault.cnf.xml on its root directory. The question is how do we do that?
I configured the CME router as follows:
Router#show running-config
Building configuration...
Current configuration : 1808 bytes
version 12.4
service timestamps debug uptime
service timestamps log uptime
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 200.200.200.1 200.200.200.10
ip dhcp excluded-address 201.201.201.1 201.201.201.10
ip dhcp pool data
   network 200.200.200.0 255.255.255.0
   default-router 200.200.200.1
ip dhcp pool ITS
   option 150 ip 201.201.201.3
   default-router 201.201.201.1
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.1
encapsulation dot1Q 1 native
ip address 200.200.200.1 255.255.255.0
interface FastEthernet0/0.2
encapsulation dot1Q 2
ip address 201.201.201.1 255.255.255.0
ip http server
ip http path flash:
control-plane
voice-port 1/0/0
voice-port 1/0/1
gatekeeper
shutdown
telephony-service
max-ephones 2
max-dn 2
ip source-address 201.201.201.1 port 2000
auto assign 1 to 2
voicemail 1500
max-conferences 4 gain -6
web admin system name admin password cisco
dn-webedit
time-webedit
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn  1
number 2000
label zeeshan label
name zeeshan
call-forward busy 1500
call-forward noan 1500 timeout 18
ephone-dn  2
number 2001
ephone  1
no multicast-moh
ephone  2
no multicast-moh
line con 0
line aux 0
line vty 0 4
login
end
These are my assumptions:
When I configured the CME as shown below, a XMLDefault.cnf file will be created and stored on tftp server.
I appreciate your help.
thanks and have a great weekend
3 Accepted Solutions
CME will generate the TFTP configuration files locally in flash and serve these to the phones. Why do you want to have the TFTP server on another device? To do that you need to copy the files that CME creates to the same path on the external server and you have to do that each time you do any modification in CME. If you ask me that will very quickly become a admin nightmare. Better to let the CME be the TFTP server.
My 2 cent :)
Please remember to rate all useful posts.
Response Signature
Sarah,
I am 100% with Roger (+5 R).
Run the TFTP server on the CME.
Can I also point out that your DHCP pool for
ITS on VLAN 2 needs a much needed line in
the config
ip dhcp pool ITS
network 201.201.201.1 255.255.255.0
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Yes that should work.
Btw, thank you for the nice rating :)
Response Signature
5 Replies 5
My 2 cent :)
Response Signature
Sarah,
the config
ip dhcp pool ITS
Alex.
Thank you Alex for the nice rating, right back at you :)
Response Signature
Thanks Roger and Alex
Just out of curiosity, If I want to have separate tftp server to provide these firm files.I do following:
1) generate cnf file first on flash.
2) then transfer these files ( cnf file and firmware files) to tftp server.
Am i correct?
thanks and have a great weekend.
Response Signature
