How to install the CME14-UL licenses in 4331V router
adeebtaqui
Level 4
Level 4
Greetings
Kindly advise How to install the CME14-UL licenses in 4331V router? We have ordered 28 smart licenses of CME.
what CLI command to used?
I cannot find any relevant information
9 Replies 9
The router by default has call home configuration and internet is reachable. Now how should I register the Smart license CME-UL using token copied from smart account.
What command to use for this to allow router to directly communication with Cisco for regsitration?
Configure Smart Licensing and the functionality you need; the router will report consumption to CSSM.
Thanks but what command on CLI to be used for this as I am not getting the correct config cli command for this. Below is the router config:
version 17.3
service password-encryption
service call-home
#do sh license all
Smart Licensing Status
Smart Licensing is ENABLED
License Conversion:
Automatic Conversion Enabled: False
Status: Not started
Export Authorization Key:
Features Authorized:
<none>
Utility:
Status: DISABLED
Smart Licensing Using Policy:
Status: ENABLED
Data Privacy:
Sending Hostname: yes
Callhome hostname privacy: DISABLED
Smart Licensing hostname privacy: DISABLED
Version privacy: DISABLED
Transport:
Type: cslu
Cslu address: <empty>
Proxy:
Not Configured
Miscellaneous:
Custom Id: <empty>
Policy:
Policy in use: Merged from multiple sources.
Reporting ACK required: yes (CISCO default)
Unenforced/Non-Export Perpetual Attributes:
First report requirement (days): 365 (CISCO default)
Reporting frequency (days): 0 (CISCO default)
Report on change (days): 90 (CISCO default)
Unenforced/Non-Export Subscription Attributes:
First report requirement (days): 90 (CISCO default)
Reporting frequency (days): 90 (CISCO default)
Enforced (Perpetual/Subscription) License Attributes:
First report requirement (days): 0 (CISCO default)
Report on change (days): 0 (CISCO default)
Export (Perpetual/Subscription) License Attributes:
Usage Reporting:
Last ACK received: <none>
Next ACK deadline: Jan 19 13:37:21 2024 KSA
Reporting push interval: 30 days
Next ACK push check: <none>
Next report push: Feb 12 11:12:52 2023 KSA
Last report push: <none>
Last report file write: <none>
Trust Code Installed: <none>
License Usage
uck9 (ISR_4331_UnifiedCommunication):
Description: uck9
Count: 1
Version: 1.0
Status: IN USE
Export status: NOT RESTRICTED
Feature Name: uck9
Feature Description: uck9
Enforcement type: NOT ENFORCED
License type: Perpetual
Product Information
UDI: PID:ISR4331/K9,SN:FDO251......
Agent Version
Smart Agent for Licensing: 5.0.6_rel/47
License Authorizations
Overall status:
Active: PID:ISR4331/K9,SN:FDO25xxxxxx
Status: NOT INSTALLED
Purchased Licenses:
No Purchase Information Available
If you search for smart license configuration IOS you’ll quite likely find what you need.
Response Signature
I registered the token on CLI of router and received ACK as below “%SIP-1-LICENSING: SIP service is Up. License #sh license all
License Conversion:
  Status: Not started
    <none>
Utility:
  Status: DISABLED
  Status: ENABLED
Data Privacy:
Transport:
  Type: Smart
  URL: https://smartreceiver.cisco.com/licservice/license
  Proxy:
    Not Configured
Miscellaneous:
  Custom Id: <empty>
Policy:
Usage Reporting:
  Last ACK received: Mar 08 12:33:35 2023 KSA
  Next ACK deadline: <none>
  Reporting push interval: 0 (no reporting)
  Next report push: <none>
  Last report push: Mar 08 12:28:34 2023 KSA
Trust Code Installed: Mar 08 12:26:46 2023 KSA
License Usage
  Description: uck9
  Count: 1
  Version: 1.0
  Status: IN USE
  Feature Name: uck9
Product Information
UDI: PID:ISR4331/K9,SN:FDO251809SZ
Agent Version
Overall status:
  Active: PID:ISR4331/K9,SN:FDO251809SZ
Purchased Licenses:
Not sure what you’re trying to get across here. What is your actual problem? If you have successfully registered the router it will use the license it needs from the virtual account in Smart Licensing. Have you configured CME on your router?
Response Signature
Issue is I am not seeing in my show license output the CME14-UL licenses that we purchased for this router and in smart account this license is still showing as Available instead of IN USE.
Below is my runn config:
version 17.3
service call-home
platform qfp utilization monitor load 80
platform punt-keepalive disable-kernel-core
hostname RIG_JBL_VRTR
boot-start-marker
boot-end-marker
ip name-server 8.8.8.8 8.8.4.4 84.235.6.55 84.235.57.230
ip domain lookup
ip domain name xx.com
ip dhcp excluded-address 172.21.31.1 172.21.31.9
ip dhcp excluded-address 172.21.31.240 172.21.31.25
ip dhcp pool VOIP
network 172.21.31.0 255.255.255.0
default-router 172.21.31.254
option 150 ip 172.21.31.254
dns-server 84.235.6.55 84.235.57.230
login on-success log
subscriber templating
no device-tracking logging theft
license udi pid ISR4331/K9 sn xxx
license boot level uck9
interface GigabitEthernet0/0/1
description CORE_SW
no ip address
negotiation auto
interface GigabitEthernet0/0/1.9
description FW
encapsulation dot1Q 9
ip address 172.x.x.x 255.255.255.0
interface GigabitEthernet0/0/1.11
description MGMT
encapsulation dot1Q 11
interface GigabitEthernet0/0/1.201
description VOICE VLAN
encapsulation dot1Q 201
ip http server
ip http authentication local
ip http secure-server
ip http client source-interface GigabitEthernet0/0/0
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 172.x.x.x
telephony-service
max-ephones 50
max-dn 50
ip source-address 172.x.x.x port 2000
ephone-dn 1
number 7001
ephone-dn 2
number 7002
ephone 1
mac-address 488B.0ABD.8BD9
button 1:1
ephone 2
mac-address 488B.0ABD.8A46
button 1:2
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
transport input ssh
call-home
! If contact email address in call-home is configured as sch-smart-licensing@cisco.com
! the email address configured in Cisco Smart License Portal will be used as contact email address to send SCH notifications.
contact-email-addr sch-smart-licensing@cisco.com
profile "CiscoTAC-1"
active
destination transport-method http
ntp server 172.x.x.x
Does gig0/0/0 interface have access to internet as that’s what you use as the source for http?
Response Signature
