IP Telephony and Phones
Personalize banner_3
Labels
I have a phone number that is setup as a Route Pattern so that calls to that number are directed to a Fax server. I need to change it so that calls to that number now get forwarded to an external phone number. What would be the easiest way to do this...
Hi for several weeks, 6825 headphones operating with DBS-210 (multicell) bases periodically send some codes, it happens when turning on the handset or changing the base.Calls on the exchange are visible as incoming from the number configured in the h...
M.S.88 by Level 2
  • 2159 Views
  • 6 replies
Hi experts, We faced a problem that some user don't hang up the call so there will have some ports be always occupied... Is there any possibility to limit call duration on ISR 4431 or 3945? Like if call duration exceed 1 hour, ISR will initiatively d...
qazzaq201 by Level 1
  • 3927 Views
  • 3 replies
Hello,Trying to connect a 8800 KEM to a 8865 phone.  Have looked at several forums and threads, tried all the settings.  Still get the same message on the phone when I connect the 8800 'the phone is not set up for the expansion module'. In CUCM have ...
Doug by Level 1
  • 16312 Views
  • 19 replies
