How to integrate CUCM to Microsoft CRM using TAPI
fgramos01
How do we use TAPI for the integration of CUCM and CRM. The CRM will acquire the information of the caller through CUCM.
Kevin Monteiro
Level 7
Level 7
Hi ,
Here is a link, you should be able to find relevant information:
http://www.cisco.com/c/en/us/products/unified-communications/unified-callconnector-microsoft-dynamics-crm/index.html
Note:
-Rate the post accordingly.
-Regards,
Kevin Monteiro
Our client wants to use TAPI for their CRM to get the CDR from CUCM.
How is it possible for the ff:
In CUCM Log of Calls Report, when is the record being saved?
  • Getting Caller ID when receiving calls...using SOAP
  • TAPI Installation Document
  • TAPI Interface
  • Demo of receiving calls thru a PC using TAPI
Your question will be much more suited for the below TAPI Developer community:
https://communities.cisco.com/community/developer/tapi
Deepak
