How to interpret CME IOS version
Noy-pi
Need help on how to interpret the IOS of CME. Currently, the Cisco 3925 is ruuning CME version 9. However, I am lost to understand the IOS version:
IOS Version: 15.2(0.13.4)PIA17
In Cisco's website, it says that the CME version 9 should have an IOS version 15.2(2)T.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
Can someone tell me what is the meaning of "PIA17" ?
Do i need to replace or upgrade the IOS 15.2(0.13.4)PIA17 to 15.2(2)T ?
Please help.
thanks,
shawn
5 Replies 5
Anas Abueideh
Level 9
Level 9
you can check you current version by running command sho telephony-service, if it is not CME version 9, you need to upgrade.
Anas
please rate if it is helpful
Hi Anas,
Thanks for the reply.
Please see the output of "show telephony-service" and "show version
shawn
your CME version is 9, I think you don't need to change your IOS
regards
Anas
please don't forget to rate the helpful posts
but do you have any idea what is the meaning of "PIA17" in my IOS? it's my first time to encounter kind of format of Cisco IOS...
Hi Shawn,
From your attachments;
PIA17  Engineering Weekly Build
It is very strange for these to be seen in a customer site unless you
were working with an engineer from Cisco who sent you this build
to address a specific need. It's just a rollup of bug fixes in an interim
format, so if it's not causing you any issues you should be good to go
If you were to open a TAC they may ask you to upgrade to the next mainline version.
ftp://ftp-eng.cisco.com/cons/workshops/isp-workshop/StudentCD-Rev-E/CCOwww/CiscoIOS.PDF
Cheers!
Rob
"Hours are like diamonds, don't let them waste
Time waits for no one, no favors has he"
- Stones
