How to know if FXO port has a connection or empty
rahul14
Good day,
Is a way to determine if  FXO ports are empty? I have a router in a remote location and want to find out which ports have an RJ-11 connection and which ones are empty.
Manish Gogna
Hi Rahul,
Check these posts
https://supportforums.cisco.com/discussion/12922566/fxofxs-port-status-connected-or-not
https://supportforums.cisco.com/discussion/10641656/fxo-finding-if-line-plugged
Manish
Thanks for your suggestions. Also is there a hunt scheme that can choose only ports that have rj-11 plugged in or to use a hunt scheme to select specific ports for outgoing calls?
aabohola2000
you can use command below
test voice port x/y/z  si-reg-read 29 1
if there is value so ports have an RJ-11 connection if not so port have no RJ-11 or there is a problem indirection of PSTN .
