11-20-2010 12:50 AM - edited 03-16-2019 02:02 AM
hi all,
My senario is:
I'm setting up CISCO VoIP from the ground, server is not ready yet.
and I received 2 reused 7961 IP Phone, when I try to setup the phone I found can't change settings.
so, I resetted it.... but I really don't know on cisco ip phone "reset" means erase firmware also,
guys, how can I load firmware into the phone even without CME ready? ( I've downloaded firmware sccp.9-0-2SR2)
thanks!
Solved! Go to Solution.
11-20-2010 06:33 AM
11-20-2010 06:33 AM
11-20-2010 11:56 PM
hi, tried but it kepts load "term61.default.loads"
modify as:
tftp log: (try tftpd32 & soloarwinds tftp)
Connection received from 172.16.4.8 on port 49152 [21/11 15:05:55.432]
Read request for file
Using local port 59836 [21/11 15:05:55.437]
Connection received from 172.16.4.8 on port 49153 [21/11 15:05:56.361]
Using local port 59837 [21/11 15:05:56.367]
Directory of D:\SCCP\cmterm-7941_7961-sccp.9-0-2SR2
11/21/2010 03:55 PM
11-21-2010 03:24 AM
hi, Jonathan, I switch to version 8.35 and it works. thx!
why cisco put a unusable fimware on it...
