how to make a call from FXS station ?
vistaprogrammer
Dear All :
i have FXS station which is related to our office kitchen and i want to allow the kitchen person to just make a normal call through voice-port 0/2/1 only to the PSTN
currently the FXS can make just internal call(just to call manger directory numbers)
voice-port 0/2/1
trunk-group freezone-land 1
supervisory disconnect dualtone mid-call
supervisory custom-cptone voice
timeouts interdigit 3
timeouts call-disconnect 5
timeouts wait-release 1
connection plar opx 100199
description Land Line 0112133181
caller-id enable
voice-port 0/2/2
trunk-group freezone-land 2
description Land Line 0112133182
caller-id enable
--- this is the FXS Port (port 0/1/1) for the Kitchen
dial-peer voice 869 pots
description Kitchen 3
destination-pattern 100109
port 0/1/1
how can i route the outbound call from (port 0/1/1) to the PSTN thru voice-port 0/2/1 only (which is FXO connected to CO: 0112133181) ?
Best Regards,
Basel
5 Replies 5
Jaime Valencia
Simply configure the dial-peer using the FXO, PRI, etc for outbound calls.
java
if this helps, please rate
Nadeem Ahmed
basel,
configure like this only
dial-peer voice 10 pots
destination-pattern <called number0112133181 >
Description<anything you can put>
port <0/2/1>
Br, Nadeem Please rate all useful post.
Dear Nadeem:
thank you for your help
basically  the number "0112133181"is the line connected to the FXO (0/2/1) in the voice gateway,
it is not the destination called number
however i did the following dial-peers:
voice translation-rule 1
 rule 1 /^9/ //
voice translation-profile remove9
 translate called 1
dial-peer voice 807 pots
 description ---- (Branch Users Outgoing Dial peer)
 translation-profile outgoing remove9
 destination-pattern 9[2345678]......
 port 0/2/2
 forward-digits all
dial-peer voice 808 pots
 description ---- Inside (Kitchen Outgoing Dial Peer)
 port 0/2/1
 forward-digits all
the problem that kitchen is going to the PSTN(Destination pattern "9[2345678]......") through the (dial-peer voice 807 pots meaning port  port 0/2/2 )
i want the kitchen to go to to the PSTN(Destination pattern "9[2345678]......") through the (dial-peer voice 808 pots meaning port  port 0/2/1 )
since the dial peer 807  is for Branch users and dial peer 808 will be for the kitchen only ?
thank you
You probably would like to use CoR to restrict usage of analog trunk to specific extension. Please check below thread and let us know in case of any question;
https://supportforums.cisco.com/discussion/12738046/cme-3-analog-lines
Other point you would like to pay attention that explicit matched digits on POTS dial peer are stripped automatically, so even in absence of translation profile to outbound call, 9 will be stripped. However you will have to remove 'forward-digits all' command.
- Vivek
Thank you Vivek for your help
the link is so helpful and it works with me .
one more question please , can i use outgoing Translation rule to block the calls going via dial peer 869  or going via port 0/1/1 to reach the different destination  like
destination-pattern 0909........
meaning i want to block the FXS analog phone to go to GSM Mobile Number?
basically i have the outgoing dial peer
dial-peer voice 805 pots
 description ---- GSM
 port 0/3/3
 forward-digits all
but i want to prevent the port 0/1/1 from using it ?
thank you
