How to make VGW to load with controller at shutdown state
Liran Farazis
Hi Guys,
I have ISR4451 voice gateways with one PRI connection.
I would like that when the VGW reload or disconnect and reconnect to power the router will boot with the same configuration it has before the reload\electricity problem but with one change - Controller e1 0/1/0 will be at shutdown state.
I tried to boot from another file at flash where I put the controller to shut state but I think that because the controller module take more time to load when the router boot it doesn't do nothing.
Thanks!
0 Replies 0
