How to modify Location parameter via SOAP in CUCM
daniel.espi
Does anyone knows how to modify Audio bandwidth parameter in Locations via SOAP? Is there any example?
Thanks in advance.
Aaron Harrison
You would need to issue a SOAP updateLocation request, as per the AXL spec.
The interface spec is documented here: (http://developer.cisco.com/web/axl/docs - pick the appropriate spec for your CM version)
Are you new to SOAP, or do you have some existing SOAP scripts you use for another purpose? If so what language?
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Aaron Harrison
Aaron
