How to move Phone Template from Call Manager 11.5 to 12.5
test60
hi,
We have 120 Phone Template to move from UCM 11.5 to 12.5.
Is there any idea how to do easily and quick ?  BAT does not seem to have option for it.
tks,
K
Andrew Skelly
Level 7
Level 7
BAT does have this available under Import/Export - Export.  Then under Device Data choose Phone Button Template.  Run the export then save the tar file from Upload/Download Files and you will have the csv for your templates that you can then import to 12.5.
Please rate helpful posts by clicking the thumbs up!
Phone template is not Phone "Button" Template,  I don't see in BAT.
7945 model has Phone template
7921 model has its own Phone template
Unfortunately there is no way to export the Phone Templates from CUCM that I am aware of.
