How to open Call manager .tar files
ronald.nutter
I am trying to open a call manager backup file to see if I can find what caused a problem I am working on.  The end game is to be able to look at different versions of the config file to see if I can find the change.  Trying not to have to do a restore and the accompanying service outage for call manager to do the reboot I am anticipating.
Tried using 7-zip but didnt have any luck.
Suggestions ?
Nadeem Ahmed
Hello Ronald,
Please refer to these post, this might help you.
https://supportforums.cisco.com/discussion/11668386/cant-open-call-manager-80-backup-files
https://supportforums.cisco.com/discussion/11255956/cucm-85-and-bars-how-extract-tar-files
Further refer to this link as well, section :Creating and Editing Backup Schedules
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/drs/8_5_1/drsag851.html
Br,
Nadeem Ahmed
Please rate all useful post.
Br, Nadeem Please rate all useful post.
Chris Deren
The backup files are encrypted since version 8.0, so unless you can heck them (there are tools on the web) you cannot simply open them.
Chris
