how to reduce 10 seconds delay from tcl script after greeting msg till call transfer
Humza Khan
I m using tcl "its-CISCO.2.0.2.0.tcl" Cisco by default script. Script file is also attached. Right now its working but having 10 seconds delay after greeting till call transfer. I want to reduce that delay. kindly reply ASAP. its urgent, i have to deploy tomorrow.
Humza Khan
Hi.
Can you, please, send also your vg config.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
